sahu
Advanced Member level 2
- Joined
- Oct 9, 2009
- Messages
- 517
- Helped
- 68
- Reputation
- 130
- Reaction score
- 63
- Trophy points
- 1,308
- Location
- Uttar pradesh (INDIA)
- Activity points
- 3,890
check out the following some chip are not supported by winpic-800 with JDM hardware this can be easily verified if you see you selected chip grayed then it can not be programmed with winpic-800 or you have enable the code protect or OSC calibration value vanished during program, i have recommended another programmer called winpic not winpic-800 or try with IC-prog
https://www.qsl.net/dl4yhf/winpicpr.html
Fragrance
when i use winpic .its result as
[CODE]Programming...
Erasing ("bulk" or "chip") ...
Programming and Verifying CODE, 0x000000..0x0003FF
Verify Error: 000000: read 003FFF, wanted 003000
Verify Error: 000001: read 003FFF, wanted 00008A
Verify Error: 000002: read 003FFF, wanted 00283C
Verify Error: 000003: read 003FFF, wanted 000000
Verify Error: 000004: read 003FFF, wanted 001A83
Verify Error: 000005: read 003FFF, wanted 00280A
Verify Error: 000006: read 003FFF, wanted 0000A5
Verify Error: 000007: read 003FFF, wanted 000E03
Verify Error: 000008: read 003FFF, wanted 0000A6
Verify Error: 000009: read 003FFF, wanted 00280F
Verify Error: 00000A: read 003FFF, wanted 001283
Verify Error: 00000B: read 003FFF, wanted 0000A5
Verify Error: 00000C: read 003FFF, wanted 000E03
Verify Error: 00000D: read 003FFF, wanted 0000A6
Verify Error: 00000E: read 003FFF, wanted 0014A6
Verify Error: 00000F: read 003FFF, wanted 00080A
Verify Error: 000010: read 003FFF, wanted 0000AD
Programming aborted after 17 errors.
Programming CONFIG, 0x002000..0x002007
Verify Error: 002007: read 003FFF, wanted 003104
ERROR: Programming FAILED !
