I recently came a across this topic as I am in the process of setting up Cadence on Suse 9.3. I followed the suggestion made and am stuck at the following point:
After step 22 I invoke /tools/cds5/tools.lnx86/bin/lmgrd –c license.dat. The error I get is that it will not reognize the host. It tells me that the host is invalid. I have no idea what to try anymore so I would appreciate any ideas. By the way, when using csh is it normal to get unknown host?
Whenever, I try to rlogin from another PC to my LINUX BOX.
IC50 does not work right, telling me I do not have a license when I try to do a simulation. However, if I try the same thing on my LINUX box, it works fine.
I fixed my problem with the host and have Cadence and LDV51 running nicely on Suse 9.3. The problem was that the license would not recognize my host name. It would always say it is invalid. This was solved by adding the host to /etc/hosts.
I don't really know a lot about Linux (yet), but you could check your license host matches the one in /etc/hosts, especially when login on from a different PC.
