alson said:In redhat 9,I run icfb & ,then display"Incorrent built binary which accesses errno, h_errono or _res directly,Needs to be fixed."
what does it mean?
kermit said:and the license file just likes this:
FEATURE 100 cdslmd 6.300 25-dec-2004 0 123DF78EC384936247C5 HOSTID=ANY
This is node-locked license format .
Just use setenv LM_LICENSE_FILE ~/license.dat
kermit
[some digits are replaced by moderator to be sure that these strings are not from valid license]
kermit said:Just because your license is not a floating license format.
IN your license file the first line must be :
SERVER arcadia15 123e9f8f 5279
and the second line must be
DAEMON cdslmd /tools/cdn/spc02.1.25/bin/cdslmd
This indicates that your license file is floating license format.
Then you can use lmgrd -c license.dat
If not,you mustnot do that.
kermit
