In what manner? Please elaborate in the same way as post #56.varunme said:so i am using portb as input and outputting to port A and E
I assume that your PORTA and PORTC did not change. About PORTE you didn't mention which pins, so I am assuming pin0 and pin1. The edited code would be:varunme said:Collect full input from portb (8bits),
and
output into porta [6bits (0 to 5)] and porte (2bits) -> but porte has three bits(0 to 3)
volatile unsigned char count = 0;
void TimerISR (void)
volatile unsigned char port_A = 0;
volatile unsigned char port_E = 0;
volatile unsigned char port_B;
unsigned char i;
//............................ the rest of the code remains as is.
PORTD = port_D; //update PORTD
port_B = PORTB; //save PORTB
for(i = 0; i < 6; i++)
if ((port_B&(1<<i)) || (count >= 1)) //pin will be set in any case if count > 0
port_A |= (1<<i);
if (i)
port_A |= (1<<(i-1));
for(i = 0; i < 2; i++)
if ((port_B&(1<<(i+6))) || (count >= 1)) //pin will be set in any case if count > 0
port_E |= (1<<i);
if (i)
port_E |= (1<<(i-1));
else
port_A |= (1<<(i+5));
PORTA |= port_A; //update PORTA
PORTE |= port_E; //update PORTE
That's funny because the code is the same with the PORTC and PORTD part which as you said is working OK.All the outputs stays at 100% , not blinking ...
No. You are declaring count variable twice. Remove the second declaration and keep the first only. This will solve the problem.varunme said:is it because, the two for loops togather ?
Sorry Varun, I can't help you on that. I am not a PIC expert and furthermore this issue is far from this thread's topic. I suggest you open a new thread for this. The code is working OK, I tested it yesterday in simulator. There is a very small bug, but unless you solve your peripheral problems on those ports, there is no point to further discuss it. When you are ready with the other issue you raised in your previous post about ports, you can come back here to finish this thread. It is almost solved anyway. :wink:hi,
Now with same code PORTD, its working perfectly, but with port A,E B its not, lot of peripherals are residing there, i am tweaking using datasheet.
As I said I don't use PIC, but even if it was in AVR, I would cut all the other ways of those IOs on the board and leave only lights and sensors related tracks. When you test the code succesfully for the bits algorithm, you can again bring in the parts you cut and write the code for them as well. You can use a cutter to scratch and eventually cut tracks and then resolder them when you're done. I wouldn't waste time on debugging and fixing bugs for code I will not make use of in the real world. When time comes in the final sample, write the code for shift register at once. If you are using any simulator then spare your time for cutting, measuring and soldering and finish the bits code in Proteus.varunme said:But for prototyping as now, isnt it difficult to code for mux and shift register ?
I think that all combinations could be made. I mentioned it at an earlier post that this could be done inside timer interrupt. This is why the function originally acquired the name "TimerISR()". It was supposed to be a timer interrupt service routine. You don't have to instantly change the lights state (I mean none will complain if lights go off a few ms after they supposed to), so you can run this from main(). Inside timer ISR only count variable will be updated and its value will be processed from main(). So this has to be a global variable.Can i use inside RTC , so that I can use like a timer ,
if a time condition is satisfied then this program has to be executed.
Since you need a time condition to be satisfied, I see no reason to drive lights from I2C interrupt. Update count variable inside timer interrupt, and process it from main(). Or entirely do it inside timer interrupt if you don't want to mess with flags. As I said in my previous post, I believe it's fine in the way it is now. But in any case I would avoid lights driving from I2C interrupt.Can i use inside RTC , so that I can use like a timer ,
yes,
I am using hardware i2c , clock
So you are saying that one pic measures time and depending on the timing condition it drives pins of the other pic to command him to do something with the lights?But i am doing the clock and
sensors and lights
in different pics , due to lack of number of pins,
if a certain time condition is satisfied, a pin goes high and its a condition for the lights to lightup in a certain way in the second pic which controls the lights, if another time is satisfied, then another pin goes high and does another lighting condition.
