- Joined
- Jul 4, 2009
- Messages
- 16,487
- Helped
- 5,157
- Reputation
- 10,347
- Reaction score
- 5,207
- Trophy points
- 1,393
- Location
- Aberdyfi, West Wales, UK
- Activity points
- 139,488
It should be like this:
Thumbwheel 'common' goes to supply.
Thumbwheel 'outputs' go in parallel to the same data input pin across all 4511s at once. Each of the four lines has a 10K to ground.
One side of all the toggle switches goes to ground.
The other side of the toggle switches go to the LE pin on one of the 4511a. This one also has a 10K to supply for each LE pin.
One side of the case switch goes to ground.
The other side of the case switch goes to the BI pin on all the 4511s joined together. This one also has a 10K to supply.
If I've got this right, the display will blank when the case switch closes and reappear the same digits as before when opened.
The thumbwheel will select the number to be displayed.
The toggle switch will lock the number into one of the LEDs.
Brian.
Brian.
