Switch_639
Member level 1
- Joined
- Dec 27, 2009
- Messages
- 34
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Port Elizabeth, South-Africa
- Activity points
- 1,542
Re: V-F Converter cct
the LM331 pin4 is connected to GND... the LF411 pin4 is connected to -VS as stated in cct... I can measure supply voltages yes at pin8 of LM and pin7 of LF... they are at VS... all in use remainder pins also give me voltage... I think I am gonna build this frequency counter cct also... at least I can use a function generator to test the counter cct and if that works I can apply the other cct to it...
this is the counter cct... I wont use the regulator cct, no need as I have PSU... the MK1 and MK2 are just different options...
https://i531.photobucket.com/albums/dd351/Switch_639/FrequencyCounter.jpg
