Genomerics
Full Member level 3
I'm using UC3845...So, how much do I need? Sorry, Genome. I don't really understand the table as in there are many voltages..
Now, I'm testing my PIC. Everything is good.
My transformer will be delivered to my place by next week. Hopefully, everything will go smoothly.
Hmmm, I can get confused as well. You want one of the versions that has a duty cycle limit of 50% and then you want one that has the higher start up and operating voltages...
That would be the UC3844 50% 16/10
You'll notice that the ones with the higher start up voltage also have a wider operating range. This is to suit off-line conversion because they will normally be started with a 'bleeder' resistor from the main high voltage DC BUS. It gives them longer to get up and running.
For modelling purposes, if you have a UC3845 model, then you would need 9V. 17.5V for the UC3844.
If you want to operate at 20KHz then you would need a bigger transformer core/bobbin. It might/will end up being rather big. Yes you would change the RT/CT components to get the different frequency.
As FvM states... no you can't strip the core out of electrical wire and use it. You need the insulation and ordinary pvc insulated wire would take up too much space and the insulation itself would be too 'soft'.
How about I try and source some parts over here and get them shipped out to you?
I'll put together a more meaningful circuit diagram later.
Genome.
