vimalkhanna
Full Member level 6
- Joined
- Aug 7, 2010
- Messages
- 322
- Helped
- 55
- Reputation
- 110
- Reaction score
- 53
- Trophy points
- 1,308
- Location
- delhi
- Activity points
- 3,224
The stored charge of the SF58 is much higher than the fast transistor IRG. As such , the conducting diodes do not switchOFF by the time the reverse diodes switch ON.As such there is a breakdown every time ...You can divert this by a small series inductance with the diodes ...OR a ferrite bead on the leads ..
The load does not drain the current as the voltage across this is not high enough .
You will need to try a switcher operating to 50KHz so that on load it drops down to 35KHz ...The PWM does not cater to this as the pulsewidth will narrow down the lack of load on the output stage.
