danny davis
Banned
If a circuit is fluctuating voltage, how do you know which transistor or IC chip is fluctuating the voltage up and down or at random?
How would a troubleshooting tech, test and pin which transistor or IC that is cause this kind of problem?
What is this called when a transistor or IC is fluctuating the voltage? the transistors is not shorted or open , so what is this called? or what state is the transistor or IC chip in?
Using Freeze or a Heat gun on the transistor won't help troubleshoot this problem, I have tried that
How would you guys approach this issue?
