Precision99
Member level 2
No, leaning back should not cause swinging unless there is friction.
I disagree. But it is hard to argue against such hand-waving statements that give no reasons or reasoning as to why the writer believes the statement to be true. Do you believe there is some fundamental reason why leaning back should not cause swinging? Do you believe there is a fundamental reason why swinging cannot be started, regardless of what the person does, without friction being involved? And if you believe there is such a fundamental reason, then you need to explain what that reason is. In other words, you need to justify your statement, otherwise you are just pulling your statement clean out of thin air.
For myself, I have the great advantage of owning a swing, and can thus report as observed fact that leaning back as I have described results in a small but entirely unambiguous swinging motion. Maybe I should get a mate to video this, and post the video.
And on top of that, I see no fundamental reason why this cannot happen (with a swing, but not with a frictionless rotatable office chair), and from an analysis of the forces and torques, I would broadly expect it to happen, though I admit that the exact details of what happens dynamically when you lean back are very complex.
If the chains were rigid rods, do you still believe that leaning back should not cause swinging?
And what does "should not" even mean? Does it mean that, off the top of your head, you reckon it "should not" happen but you are not really sure, or do you mean "cannot", which would mean you have some firm basis in physics for making your statement?
As matters stand, your unevidenced statement has little if any value.
