Precision99
Member level 2
you have created potential angular momentum which is released when the bob is released - this is same as hitting the pendulum/bob - this is not the same as trying to start it from rest ... your logic is faulty again.
Wrong on every count. Go straight to jail. Do not pass GO. Do not collect $200.
(a) There is no such thing as "potential angular momentum".
(b) Releasing an object from rest is most certainly not the same as "hitting" the object.
(c) A pendulum most certainly can be started from rest. And at the instant it is released, it has no angular momentum.
(d) It gains angular momentum as it accelerates towards the bottom of the stroke.
You have utterly failed to answer my question as to where the torque comes from for this angular acceleration, given that nothing physically touches the pendulum to accelerate it, and given that the overhead pivot is frictionless.
The answer is very simple, easy peasy. The force of gravity provides the torque. Provided that the string is not vertical at the bottom of the stroke, the vertical downward force of gravity has a component at right angles to the string, and therefore produces a torque, that in turn produces the angular acceleration. With a simple vector diagram, the component of the gravitational force (mg) that is at right angles to the string is easily shown to be mgSin(theta), where theta is the angle of the string with respect to the vertical.
FYI, for small angles of theta, Sin(theta) is approximately equal to theta, so so for small angles, the restoring torque is approximately proportional to the angle. This (if you can remember your physics) is the condition for producing (angular) Simple Harmonic Motion. And SHM produces a sinusoidal motion, that is, the angular displacement vs time is approximately a sine wave for small amplitudes of oscillation.
Hold the axle of your spinning bike wheel (one hand supporting each end) so that the axle is horizontal. Now, change the orientation of the axle by rotating it in the horizontal plane. A hefty reaction force will be produced, trying to lift one end of the axle, and lower the other end. These vertical forces on the ends of the axle are at right angles to your horizontal movement of the ends of the axle, and therefore you do no work in rotating the axle in the horizontal plane. If you don't believe me, try it. And actually, this must be the case, because if the axle genuinely resisted your altering of it's orientation (rather than producing a force at right angles) then you would be doing work against that resistance. And then physics would be in real trouble. Where would the work done end up? As explained previously, it can't end up increasing the rotational speed of the wheel, because no torque can be transferred through the bearing to the wheel to speed it up.
The "reaction" force is perpendicular to the movement, so no work is done. However, your arms apply a horisontal force, and there is a horisontal movement (the one that creates the reaction force), so your arms are doing some work.
The work ends up as a rotation of yourself and the planet you stand/sit on.
By using a large gyro you can slow down the rotation of the earth and extract that as energy.
You contradict yourself. First you state "no work is done". Then, in the next sentence you say that "your arms are doing some work"!
I can assure you that no work is done, and that therefore your arms are doing no work. Work is force times displacement, where force is the force (or vector component of a force) in the same direction as the displacement. Therefore, if the force is a right angles to the displacement, as it is in this example, then no work is done, period.
But you still have not told us exactly how you could use a gyro to "slow down the rotation of the earth and extract that as energy." Please explain in detail, using a spinning bicycle wheel for your example. For simplicity, we can assume that the experimental is carried out at the N or S pole. Is the plane of the spinning bicycle wheel horizontal or vertical? I'm guessing vertical, though you have never told us.
And then what? It's not good enough to blandly state that "By using a large gyro you can slow down the rotation of the earth and extract that as energy." You need to give us the details as to how you would actually do it.
