ianomaley said:Does anybody has information or a brief tutorial on protections at the input stage of a oscilloscope? For a general instrument probably end users may apply out-of-range- voltages frequently.
Ian
Yes, comparison in the FPGA (or CPLD)I have read the sch,and there seems to be one external trig souce, but can't see the internal one,do you implement this using the logic part?
I hope (why not ?)Can it trig stable?
Have a look at Fox-toolkit, it's stable, easy to program, cross-plattform, nice looking, ...xipen said:Hi,all,
I've read the post in page 10 about software GUI,there are sveral libs that can be used aiming for cross platform:
Thanks!
For limited bandwith better solution will be Gameboy DSO, since it is cheap and even if you damage it total lost will be much lower than if you burn your mobile.TeeSee said:Here's a quick theory to tear apart. I have a Java enable N0kia phone.
How would you be with a bit of smart Java programming and a simple interface circuit to plug into the bottom of the phone (using the hands-free microphone jack) making a (limited bandwidth) mini-handheld scope?
Where did you see that MAX1180 is only 50 MSPS per channel ?Yet, i'm surprised you work that had for a 50Msps scope only ! Idea
(max1180 is 105Msps for both channels)
Indeed :?Top challenge would be to tweak a PC motherboard and go to Gsps range (similar to lecroy architecture) but this may be too hot with hobbyist ressources
