Difference between Main Antenna and Rx-diversity antenna
newbie_hs
I am using Quectel SC200 in my design .Below is the description of it's antenna interface.
SC200E-CE/-EM/-NA and SC206E-EM/-NA provide four antenna interfaces for the main,
Rx-diversity,Wi-Fi/Bluetooth, and GNSS antennas respectively.
I understood all the other antenna specifications except main, Rx-diversity antenna.
May I know the difference between main antenna and Rx-diversity antenna and why we are using it
Solution
This is for LTE.
Following the link from your initial post, we find this:
"The SC200E series supports multiple-input multiple-output (MIMO) technology. The use of multiple antennas at the receiver end on the same frequency band greatly minimizes errors and improves the data speed."
This is for LTE.
Solution
LaTeX Commands Quick-Menu:
