CB0703-PCB for "PICkit 2" DIY(Do It Yourself) fans
pk2erroor:unable to enter debug mode +pic16f877a
blueroomelectronics said:
Where do you get the 9V? Most PK2 are USB powered 5V
That LM317 circuit use external power suply, for high amper target boards.
My experinmental boards use Vdd from Pickit2.
For chip programming in zif socket and low power targets ,
I use this circuit in PK2 (using USB power)
This TLV4110 is Rail to Rail / 300mA out ( TI sample aval.)
    funnynypd
pickit 2 lite pcb
Hi
A general question to all for all PIC programmers and specially PK2 5V version can I connect it to a self powered 3V target board.
Thanks
sadat007
pic18f14k50-icd
sadat007 said:
Hi
Thanks
sadat007
yes you can program
    funnynypd
logic analyzer pickit 2 i2c pull down
what are the eproms for ?
Are they something to do with debugging ?
wizpic
pic16f688 isp header
As far as the EEPROM function, even the microchip guy doesn't give a clear clue. There is lots of "guessing" on Microchip forum.
Microchip has an originall plan, but, so far, there is no implementation on those EEPROMs yet.
Funny
how to program pic24fj64ga002 with pickit 2
wizpic
Microchip say, it is for program without a computer then the EEProm store the firmware to burn and when you press the program buton this firmware is store in your target, but isn't implemented yet.
icsp + pic16f685
sadat007 said:
Hi
Thanks
sadat007
Before you connect both, please check the VPP, make sure it is under the spec of your microcontroller. For most chips, the VPP has a wide range, but you don't want to send a over-voltage to the uc when programmming.
clone pickit
sadat007 said:
Hi
For PK2 I have some questions hope one of u may answer!
1. Can I use 18f2553?
sada007
Have you tried the 18F2553 chipset with the PICkit 2 hex file?
I checked the data sheet of 18F2553, the major difference to a 18F2550 is the A/D converter module.
The configuration bit seems the same.
So I do recommend you do a test if you got the chip, and let everybody know what you find.
Regards,
Funny N.
diy pickit2 clone
funnynypd
I've been looking at your schematic and the original PICKIT 2 schematic and I have noticed that the MCLR pin only goes to the ICSP connector
Is that correct I thought that they needed a 4K7 resistor to VDD for it to work
or is it like the PIC16F628 where you can turn mclr off ?
wizpic
    funnynypd
24lc256 + pic24f + program
wizpic said:
funnynypd
wizpic
Hi wizpic,
It is very good of you for noticing this kind of small detail. Please check the attached configuration bit for 18F2550 (the line is highlighted).
When mclr bit is turn off, it is only used as VPP pin on the PICkit2 design. That explains why it works.
I believe this is a relatively "new" feature on most of the "recent released" PICs. :D
    funnynypd
program pic16f916 via serial port and breadboard?
dsPIC24F said:
wizpic said:
funnynypd
wizpic
Hi wizpic,
Cool that answered my question, I thought it was a bit strange first time I have come accross that on the 18 series :D
I'm just dying to build it now i have got time on my hands
thanks
wizpic
    funnynypd
pickit3 clone
sadat007 said:
Hi
2. Please upload/point me the simplest pk2 that u tested.
3. Can I use variable VDD with lm317 and fixed VPP to make a simplest PK2?
4. VDD also fixed with option for other VDD like 3V will be provided on the target board its self.
5. What happed for the data and clock pins if PK2 rinning on 5V and target running on 3V?
thanks
sada007
The PIC18F2553 should work, anybody tried?
    funnynypd
connecting to pic18f46k20
Can any one tell me what is the standard ISP/ICSP connector and configuration recommended by microchip?
As I noticed that the connector in above PICKIT2 LITE version is differ from EPIC programmer!
Also please conform me that the VDD from PICKIT2 LITE SE is through transistor, will it provide the voltage only during programming or all the time to the target?
As I will receive PCB from my local manufacturer I will test 18F2553 too.
Thanks
sadat007
    funnynypd
pic18f2680 pcb
The PICKit2 ICSP pin-out sequence is different than the ICD2, though they are exactly the same ICSP pins.
(Microchip is also selling a converter for PICkit2 to match the ICD2 pin-sequence),
For DIY fans, it is possible to adjust the cable accordingly and make it working.
connecting dspic30f3014 with pic kit
VDD is controlled with a P-Channel FET, if you use a transistor you'll get a small voltage drop.
I mean from Transistor--> FET..........but what I mean to ask that will it only ON during programming? If yes then for continues target board power we have to add another point in the connector for such case. This you can see in EPIC programmer
VDD and 5V two points.
Thanks
sadat007
    funnynypd
