In other words, Rdson has a rather large variation range and can be considerably higher than assumed in your simulation.2SK104
N-Channel JFET
Various
field effect transistors,transistors
V(BR)GSS (V)=30
I(D) Abs. Drain Current (A)=20m
I(G) Max. (A)=10m
Absolute Max. Power Diss. (W)=250m
I(GSS) Max. (A)=10n
@V(GS) (V) (Test Condition)=30
V(GS)off Min. (V)=.25
V(GS)off Max. (V)=4.5
@V(DS) (V) (Test Condition)=5.0
@I(D) (A) (Test Condition)=10u
I(DSS) Min. (A)=500u
I(DSS) Max. (A)=12m
I have never seen a SK104 or SK105 datasheet. A summarized specification says:
The left waveform is apparently indicating an unstable amplitude control loop.
How do you call a control process that maintains steady oscillations otherwise? I just realized, that the frequency seems to be about 50 Hz, so it may be trivial hum as well.I don`t think that the loop is "unstable"
With both waveforms, the timebase is apparently uncalibrated. If the oscillator is working at 1 kHz, then the control signal is "swinging" at about 50 Hz frequency.Can you confirm the following readings?
Output: 10 mV,pp at app 3 kHz
Gate control: 10 mV,pp at app 200 Hz?
If you refer circuit diagram LPF (first order) is configured for 10Hz.
Main Oscillation Frequency: 1KHz
Output frequency from AC-to-DC (Full-wave rectifier): 2 x 1KHz = 2KHz
So the signal at gate should be 2KHz (ripple) riding on 10Hz wave.
Am I correct ?
But you should be able to determine the frequency with sufficient accuracy, and e.g. not have to guess about a frequency of 10 Hz if it's actually 50 - 100.Swp. var. (calibrated=no) was adjusted to see the wave otherwise It was shifting.
I am reluctant to call such a loop "unstable", because it is a kind of "instability" which cannot be avoided in a non-linear and discontinuous control loop (caused primarily by the rectification).
