Bode plot
Pixelx
Member level 3
Member level 3
Is it possible to measure the Bode characteristic of the converter using a generator and an oscilloscope? I want to determine the stability reserve of the phase and amplitude. I have a transformer injecting the DHO814 oscilloscope, an FY6900 generator, and I wrote a code in python that injects voltage into the feedback loop on a 51ohm resistor.
I have the impression that my data reading from the oscilloscope is too slow in relation to the regulation. It seems to me that if I read every 100ms, the converter will stabilize by then? Can it be done on the equipment I have?
Does the oscilloscope have to be set to the AC range? Because that's what I did
This is how I determine the gain, I don't know if it's right?
amplitude_ratio = (np.max(vout)) / (np.max(vin))
gain_db.append(20 * np.log10(amplitude_ratio))
Yellow input waveform and blue output waveform
Is it possible to determine such a Bode characteristic in the range from 100Hz to 1MHz in LtSpice of this BUCK converter?
To analyze AC transfer function of switching converter, the simulator must support periodic steady state (PSS) analysis or similar methods. Ltspice doesn't. Measurement in transient analysis with frequency stepped sine excitation can be a workaround.
Also there's no useful transfer function above 1/2 of pwm frequency.
I have another question from theory. If we have the G(s) converter transmittance, we can simply go to the spectral form G(jw), then generally the transmittance concerns the steady state when it is working or the moment of switching on the converter as well? The moment of switching on, i.e. once the voltage is supplied to the converter input and there is always some unsteady state and does such a transmittance cover it? It seems to me that it does not quite, because we inject the disturbance when the system is already working, i.e. we have a specific G(s) transmittance.
Is it possible to somehow practically determine the formula of the transmittance of such a real converter that we are studying so that its equation is written in the form of G(s)?
If so, are there any tools that support this, or any formulas that could be used to determine it?
G(s) of modulator and switching stage is the time-continuous equivalent of actual discontinuous transfer function, e.g. the average response over a switching period.
Also i downloaded the attached from LTspice website years ago...it claims to do bode plot from LTspice sim
At 2:15 onwards of this video you hear the designer of LTspice saying that Bode plots arent particularly important for current mode controlled SMPSs...
  • LTC3854 Bode Analysis.zip
All the more reason to perform square wave step load tests for static %error DC load and AC dynamic sq. wave load %error.
Find the step frequency with a BJT active load to find where error begins to amplify the V step error from low f to high f.
This is where the gain margin is poorest and attenuates error feedback resulting in more error.( if poorly designed current compensation)
Compare static load errors with dynamic square wave loads and make a design budget to include all sources of error.
1. I made the characteristics of the 1.2mH 10uF LC filter and confirm it with simulation in LTSpice.
2. Problem with phase measurement. I use the Hilbert transform, but when I reduce the amplitude on the generator, errors appear later. Do you know a better method of determining the phase? And not susceptible to noise?
3. I took the characteristics of the injection transformer using the measuring equipment that I build and also compared it with VNA (measurement from 9kHz to 1MHz). You can see that the transformer works very well up to 1MHz, even up to 2MHz, I think it can be used.
4. I injected the disturbance into the DC/DC converter
I really have a problem with noise. I limited the oscilloscope bandwidth to 20MHz of the X1 probe. I see that the noise is coming through the transformer. It is wound with twisted pair Internet. Maybe some metal can for this transformer to shield it and connect it to PE?
4. The disturbance I injected is 2V pk-pk. I know a lot, but if I give a lower value, the noise is high and the GAIN is lower. With such a value, you can see that I have obtained the GAIN characteristic like the manufacturer, but the problem with measuring the phase is high noise and what is the best method to calculate it?
Please advise me, because the topic is really interesting, I would like to isolate this noise somehow and hide this transformer in something. It's probably a problem with the electric field?
LTspice does have their own way of deriving bode plots automatically from transient simulations, they call it the FRA. It's not as nice as PSS with Cadence Spectre, but is better than manually stepping excitation frequency.
--- Updated ---
As others have already said, you need a scope with an averaging acquisition mode. AFAIK most basic scopes made in the last ten years should have this.
Also when using averaging mode it is imperative that you have a good trigger source for the scope. Do not try and trigger from waveforms coming from the SMPS itself. If you signal generator has a trigger output, use that. If not, use the signal generator's output routed to another scope channel.
Knowing the model numbers of your scope and signal generator would help us give more specific advice.
It's a new feature implemented with recent Ltspice versions. I wasn't aware of it yet, I guess most Ltspice users neither. Thanks.
Is it worth hiding the transformer in an aluminum housing connected to PE?
It worked. This is the effect. What do you think about this measurement?
Looks good...since your noise abatement procedures seem to give good results...why not go further and do more noise killing...eg
1....the fet heatsink connect it to local circuit ground...(use insulation pads on heatsink if nec essary)
2...Use small Y cap across your injection transformer (ie some MLCC in your case)
3...slow down the gate voltage rise as much as you can get away with. (ie damp the switching of the fet as much as poss).
4...Use more pcb layers so you have a huge unbroken ground plance right under all your smps.
use stitching vias to it all over the board.
5...use a common mode choke at input connections to your smps.
6...use twisted pair cable off to your dummy load...make it power coax connection if poss
7...nice little alu "cups" to go over your switching diode and fet and then connect these to local ground.
8...put the whole smps in a metal container with a y cap from the container to the ground in the smps pcb.
9...etc etc
Well, it's a transformer and I have an injection one and I have to add 100pF on the primary and secondary side? In the simulation I did it had no effect
yes because it is common mode noise that you are fighting, and this doesnt show on the scope.
--- Updated ---
Another good way to get low noise from DCDC is to put it in a metal enclosure.....then have a plane in the PCB which is "chassis plane"....connect the metal enclosure to the chassis plane.....and then also y capacitor connect the chassis plane to the SMPS ground plane.
This gives superb y capacitor coupling of the metal enclosure to the SMPS...and really makes it hard for any noise to escape the SMPS.
Combien it with common mode chokes from large to small ones with low turns aswell.
Also beware noise escaping from your dummy load...you can similarly shield that off aswell....and have a common mode choke to it.
I have such an aluminum casing with a thickness of 2 mm. It will be good for an electric field but magnetic it does not work so well, but capacitive couplings probably play a more important role here, i.e. an electric field?
Connection to PE enclousure will reduce common mode noise?
How to add these common mode here? I could somehow draw a diagram and show how to implement it in practice so that I have as few parasitic elements as possible L and C
The Y caps help with B field aswell...because they re-route the disturbance currents such that those disturbance currents do not flow in such a wide area loop...whereby they would cause a high B field disturbance.
Actually since your injection transformer is likely with sinusoidal currents then maybe its not so important to y cap it......but yes, you have to connect its metal case to something.......so i guess connecting it to cct ground would be a good idea.....possibly connecting it with a Y capacitor instead of direct connection
Write your reply...
LaTeX Commands Quick-Menu:
