Audio Amplifier. Which class should I use?
Hi shayaan
Let me simplify it ! at first you need a background about mosfet and bjt . at mosfet if you put 15 volts across the GS junction , the DS will become short circuit . but in fact not completely short circuit . the channel will have a little value of resistance . that called Rdson . it is low . ( and sometimes negligible ) .and for bjt : if you put 0.6 volts ( approx ) across the BE junction , the CE will become short circuit . but here you will have base current ( i.e form mosfet there is not any current for gate . because it has pretty high impedance ) . so as you know IC= beta*ib . hence , when vbe is 0.6 volts , ( or a bit more ) but the base current is limited , thus the collector current is limited .
you understand it ?
Hello sir.
Thanks. I knew all these. But now you told me it in more simplify so I will say yes, I have understood.
Hello sir.
Humm . shayaan . before continue , let me optimize a thing : one of my best friends noticed me about behavior of bjt . and i think it is better to clarifying it : CE of a bjt won't be short circuit , exactly . it will have a voltage across it self that called VCE sat . ( when we prepared BE voltage and base current .) did you know this ?
Ok now let me continue . so , as you told you are agree with me about on / off region of a bjt or a mosfet . ok ? so , see below , please :
Can you simulate this circuit in pspice and show me the voltage across the resistor and across the DS junction , please ? try to change duty cycle , ( by variation in PW ) . and show me the result . what about power across the resistor ? or power across the mosfet ? can you compare them together ?
Best Wishes
Goldsmith
Yes sir I know this.
248.3V across resistor.
You also asked voltage across DS junction. But sir DS junction will be act as short.
Sir tried by changing PW, I see the clear result when I decrease PW to 700ns or further low. I have attached thumbnail.
I=4amp to 5amp (approx.) and V=248.3V
P=VI
P=(248.3)(5amp)
P=1241.5W
P=1.2KW
Sir I am confused how to calculate power dissipation across MOSFET..
How much my calculation is right? I have attached thumbnails.
Hi shayaan
Good night
Of course we can suppose that DS is short circuit ( approximately ) but i want the wave form of the voltage across it ( use differential probe ) ( do you know what is differential probe in Pspice ?
Why 700ns ? of course it is low . increase it until nearby 3.8 usec or decrease it as low as 1usec .
Shayaan , can you remember how to calculate the average of a square function ? if yes , you have to show me the average value of power ! if you show me that i will describe my reason by these actions !and about power calculation across the mosfet use a wattage probe on the surface of your mosfet . show me it's average value !
Best Wishes
Goldsmith
320W (approx.) is dissipated across MOSFET.
And I know how to use differential probes. I have attached result.
Sir I know the formula of average of the square wave but sir I don't know what limits should I use?
Why your maximum time is 1usec in measurement ? it should be around 20usec hence we can talk about it's power ! increase maximum time of simulation as large as 20usec . and show me again the results .
BTW : why integral ?( limits ?) we have calculated a result for that integral . duty cycle* amplitude of your function
Sir you mean by this PW?
Yes sir, we have evaluated integral. Now we have formula,
Average=amplitude * D.C.
Sir I have given amplitude with 1.2KW
But sir duty cycle??
Hi shayaan .
No of course i'm not referring to the PW . i referred to Edit simulation time ! ok ?
And about Duty cycle .
I think i told you at past . but no problem . again : Ton/T T is 1/period time . ok ?
Best Wishes :wink:
Goldsmith
Sir I don't know how to edit simulation time. how much time should I set, I don't know.
Sir still confusing.
Average=1.2K * 1/period
Like this?
Sorry if my descriptions weren't as clear as enough .
see below , please . i told you what step needed ! increase it as large as 20 usec :
And about duty cycle , my mean was not that ! let me give an example : consider that we have a square wave , with amplitude = 50 volts and frequency = 250KHZ and D.C=0.5 ( it means ton =2usec ) . t=4usec . and ton =2 usec .
D.C= ton/T ======> 2/4=0.5 . ok ? so can you find your own ?
Don't lose your hope ! ( i believe that you will learn these things very soon and then you will laugh to these simple problems ! :smile:)
Good luck
Goldsmith
Thanks for reply sir.
Now I have understood but with little confusion.
1) You told me to increase step as large as 20usec. But how would I know how much I should increase step? Because every time you don't have me to tell me.
2) I know the formula for D.C. But how to know the value of ton and T? as you have used ton=2 and T=4. What should I use? Is it given to me anywhere?
there isn't any special methodology ! simply , i told you to do that because thus we can see some cycles of this square wave ! is it unclear ?
You can measure it from your waveform ! but don't worry about it ! you will select it at future ! don't forget that i still didn't tell you what is my purpose by these things ! i bet after some day you will be curious and wonderful about what i have tried to do with your mind !
Yes sir, because by increasing step I can't see any cycle further. here is attachment with 20usec step.
So by this time can I use D.C.=0.5?
here is attachment
Sorry sir... I have managed pulse width..
Now I have result... attached.
Hi shayaan
Well , now it is good .calculate average power of RL and average loss power across the DS and show me the result of your calculations .
Hello sir..
Average for RL's power:
Average=amplitude*D.C.
Average=1.2K*0.5
Average=600W
Average of Ploss across DS:
Average=320*0.5
Average=160W
Here is my calculation.
Yes sir I can,
efficiency = pout/(pout+ploss) *100
efficiency = 600/(600+160)*100
efficiency = 78.94%
