Pipeline
- Joined
- Dec 7, 2004
- Messages
- 118
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,296
- Activity points
- 875
question No.4:
using positive feedback, stable?
SkyHigh said:To simplify my answer, I am refering that there is no DC voltage gain.
It depends which point you are driving. There is a Small-Signal Transconductance Gain, gm and it's a function of AC current gain, hfe. There is however DC current gain, or HFE, which is fixed with the BJT.
jordan76 said:Hi eda4you,
You really make a good point! One small correction:
Based on your analysis, Ic4 = Vt*ln4/R ≈ 36mV / 36kΩ = 1uA instead of 1mA.
Hi SkyHigh,
This is not a wilson current source. Indeed it is a kind of current source.
regards,
jordan76
Puppet1 said:I have a further question (Interview Question):
Looking up into the source of a MOS transistor (say NMOS) at low frequencies we see an impedance of 1/gm. As we go higher in frequency what do we see ? Do we see a higher impedance or a lower impedance ?
Puppet1 said:Hello Steer,
I made an edit to my question and put it above, the NMOS transistor is in saturation with a drain tied to gate and a CONSTANT current source flowing through the drain.
eda4you said:Do you know the pros and cons of this circuit or how it is called?
