Analog CMOS Circuit Design, OPAMP problem.
mertbaba
Newbie
I will design an integrated circuit OPAMP in Cadence. I have some problems while designing the circuit. I am planning to use telescopic cascode amplifier and for the second stage, i am planning to use single stage ota design. However, after designing the circuit, I could not observe the desired values. Do you guys have any recommendation for the circuit? The specifications are given below. Thanks for every kinds of helps from now.
1- Input referred voltage noise <7 nV/√Hz
2- Gain bandwidth product (unity gain bandwidth) >5MHz
• Voltage supply 3.3V
• Should be able to drive at least 1pF capacitance
• Output voltage swing, 0.4V-2.9V
• 1/f noise corner <10kHz
• Open loop DC gain >100dB
• Power: minimize <1mA is possible
• You are given a reference current of 10µA, and generate the required biasing
What do you mean by the above? Which values are not being observed?
What does the above sentence mean?
Are the transistors biased properly?
Have you set the Gm correctly?
Is this a fully differential amplifier? Do you have CMFB?
Show your circuit so we know what is going on.
LaTeX Commands Quick-Menu:
