PlanarMetamaterials
- Joined
- Jun 13, 2012
- Messages
- 1,476
- Helped
- 407
- Reputation
- 818
- Reaction score
- 385
- Trophy points
- 1,363
- Location
- Edmonton, Canada
- Activity points
- 9,960
1. What do you mean by This type of comparison is commonly used to derive relations between the modal and terminal domain representations of various properties. ?
I mean, comparing modal and terminal-domain equations in order to relate the two. For example, in Paul's text, he compares equations 7.7 (the terminal domain equations) with 7.9 (the modal domain equations) to get the conversion of propagation constants between domains 7.10.
2. Why the matrices inside equations (6a) and (6b) only contain entries at the diagonal ?
Similar to the case of the modal and terminal propagation constants, the matrices of the per-unit-length admittances and impedances are diagonal because we choose them to be that way. Let me explain it another way:
We naturally know the terminal-domain representation of the system. We are trying to find out how to get the properties of the decoupled system (modal domain) from this terminal domain. So we know in advance that we are looking for the decoupled system (which, by definition, contains only diagonal matrices), and what we are trying to solve is the change of bases that will convert between the two representations. The math shows us that these change of bases are the transformation matrices [Tv] and [Ti] (specifically, equations 4 in the paper).
