munzir
Full Member level 6
The description clearly refers to an inductive transducer. Instead of the suggested LVDT design, it sounds more like center-tapped coil, that works in combination with a moving core and a differential inductance bridge.
would you like to elaborate it more ?
What would be the output of that inductive transducer that is going to the tension controller box to control the tension of the plastic packaging film ?
In this process ( plastic packaging film example ) , could you tell which one would be better to use inductive transducer or LVDT ?
thanks
