Tahmid
Advanced Member level 6
- Joined
- Jun 17, 2008
- Messages
- 4,764
- Helped
- 1,799
- Reputation
- 3,590
- Reaction score
- 1,662
- Trophy points
- 1,413
- Location
- Berkeley, California
- Activity points
- 30,714
In that case, check the high voltage bus. It can not exceed 500v (maximum limit of the IR2110). Also, make sure the MOSFETs can handle the high voltage.
Hope this helps.
Tahmid.
---------- Post added at 14:00 ---------- Previous post was at 14:00 ----------
With no input signal, nothing should happen.
---------- Post added at 14:01 ---------- Previous post was at 14:00 ----------
There, I think I see the problem. Connect pin 2 and pin 13 (Ground) together. That should solve it.
---------- Post added at 14:02 ---------- Previous post was at 14:01 ----------
And, the ground for the IR2110 and the high voltage ground should be the same. There should be a common ground.
Hope this helps.
Tahmid.
