Raeiu
Newbie level 5
Hi everyone, first of all sorry for my bad english.
I have a problem with this code. It generates a csv file where writes stimuli for a TB (external).
It writes a first line of text with signals name, in the second line should write the first test case (text), after this writes signals and then: second test case, signals, third test case ecc.
An example of what i would like to achieve:
But it "skip" the second line of text: it writes a line of signals and after #TC-1 and i don't understand why. (see attach file)
For write test cases texts i used a process that, when the signal test_case is '1', signal tc_write write the line, test_case turn '0', wait for xx ns, and then the signals (surely there is a better way to do this).
I hope I was clear in my explanation.
#simENA | D | Reset | Enable | CLK |
#TC-1 | ||||
0 | 0 | 1 | 0 | 1 |
1 | 0 | 1 | 0 | 0 |
#TC-2 | ||||
#TC-3 | ||||
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_TEXTIO.ALL;
USE STD.TEXTIO.ALL;
USE STD.ENV.STOP;
ENTITY write_stimuli IS
END write_stimuli;
ARCHITECTURE RTL OF write_stimuli IS
SIGNAL simCLK : STD_LOGIC; --simulation clk
SIGNAL simENA : STD_LOGIC; --simulation enable. It's used on tb (external)
SIGNAL write_tc : STRING(1 TO 32);
SIGNAL test_case: STD_LOGIC;
-- FUNCTION STRING PAD
FUNCTION PADDED_STRING(s: STRING; n: POSITIVE) RETURN STRING IS
VARIABLE ps: STRING(1 TO n) := (OTHERS => ' ');
BEGIN
IF s'LENGTH >= n THEN
ps := s(1 TO n); --- truncate string
ELSE
ps(1 TO s'LENGTH) := s;
ps(s'LENGTH + 1 TO n) := (OTHERS => ' ');
END IF;
RETURN ps;
END;
-- PROCEDURE
PROCEDURE PWRITE(VARIABLE l: INOUT LINE; msg: IN STRING) IS
VARIABLE tab : CHARACTER := ';';
BEGIN
WRITE(l, msg);
WRITE(l, tab);
END PROCEDURE;
PROCEDURE PWRITE(VARIABLE l: INOUT LINE; sig: IN STD_LOGIC) IS
BEGIN
WRITE(l, sig);
WRITE(l, tab);
END PROCEDURE;
PROCEDURE TCWRITE(VARIABLE l: INOUT LINE; sig: IN STRING; FILE f: TEXT) IS
BEGIN
WRITE(l, sig);
WRITE(l, tab);
WRITELINE(f, l);
END PROCEDURE;
-- DICHIARAZIONE DEI SEGNALI
-- In questa sezione bisogna scrivere i segnali preceduti dal prefisso
-- "my". Questi sono i segnali necessari per la simulazione.
SIGNAL reset : STD_LOGIC;
SIGNAL enable : STD_LOGIC;
SIGNAL clk : STD_LOGIC;
SIGNAL D : STD_LOGIC;
SIGNAL Q : STD_LOGIC;
BEGIN
write_process: PROCESS
FILE stimulus : TEXT OPEN WRITE_MODE IS ("Stimoli.csv");
VARIABLE lo : LINE;
VARIABLE text_done : BOOLEAN := FALSE;
VARIABLE cont : natural := 1;
BEGIN
IF (text_done = FALSE) THEN -- Write first line on csv
PWRITE(lo, "#simENA");
PWRITE(lo, "D");
PWRITE(lo, "reset");
PWRITE(lo, "enable");
PWRITE(lo, "clk");
PWRITE(lo, "EXPECTED");
PWRITE(lo, "Q");
PWRITE(lo, "RESULT");
WRITELINE(stimulus, lo);
text_done := TRUE;
END IF;
IF (text_done = TRUE) THEN -- write test case
IF (test_case = '1') THEN
TCWRITE(lo, write_tc, stimulus);
END IF;
END IF;
IF (text_done = TRUE) THEN -- Write signals on csv
WAIT UNTIL simCLK <= '1';
PWRITE(lo, simENA);
PWRITE(lo, D);
PWRITE(lo, reset);
PWRITE(lo, enable);
PWRITE(lo, clk);
PWRITE(lo, string'(" "));
PWRITE(lo, Q);
cont := cont + 1;
IF (cont = 30) THEN
FILE_CLOSE(stimulus);
STOP;
END IF;
END IF;
END PROCESS;
-- SIGNAL PROCESS
simENA_process: PROCESS
BEGIN
simENA <= '0';
WAIT FOR 10 ns;
simENA <= '1';
WAIT FOR 70 ns;
simENA <= '0';
WAIT FOR 10 ns;
simENA <= '1';
WAIT;
END PROCESS;
D_process: PROCESS
BEGIN
D <= '0';
WAIT FOR 40 ns;
D <= '1';
WAIT FOR 80 ns;
D <= '0';
WAIT FOR 20 ns;
D <= '1';
WAIT;
END PROCESS;
reset_PROCESS: PROCESS
BEGIN
reset <= '1';
WAIT FOR 10 ns;
reset <= '0';
WAIT FOR 30 ns;
reset <= '1';
WAIT FOR 10 ns;
reset <= '0';
WAIT FOR 30 ns;
reset <= '1';
WAIT;
END PROCESS;
enable_process: PROCESS
BEGIN
enable <= '0';
WAIT FOR 80 ns;
enable <= '1';
WAIT FOR 80 ns;
enable <= '0';
WAIT FOR 30 ns;
enable <= '1';
WAIT;
END PROCESS;
myclk_process: PROCESS
BEGIN
clk <= '0';
WAIT FOR 10 ns;
clk <= '1';
WAIT FOR 10 ns;
END PROCESS;
Q_process: PROCESS
BEGIN
Q <= '0';
WAIT FOR 20 ns;
Q <= '1';
WAIT FOR 20 ns;
Q <= '0';
WAIT FOR 20 ns;
Q <= '1';
WAIT FOR 20 ns;
Q <= '0';
WAIT;
END PROCESS;
-- SIMULATION CLK
simCLK_process: PROCESS
BEGIN
simCLK <= '0';
WAIT FOR 10 ns;
simCLK <= '1';
WAIT FOR 10 ns;
END PROCESS;
-- WRITE TEST CASE
write_TC_process: PROCESS
BEGIN
test_case <= '1';
write_tc <= PADDED_STRING("#TC-1", 32);
WAIT FOR 10 ns;
test_case <= '0';
WAIT FOR 60 ns;
test_case <= '1';
write_tc <= PADDED_STRING("#TC-2", 32);
WAIT FOR 10 ns;
test_case <= '0';
WAIT FOR 20 ns;
test_case <= '1';
write_tc <= PADDED_STRING("#TC-3", 32);
WAIT FOR 10 ns;
test_case <= '0';
WAIT FOR 40 ns;
test_case <= '1';
write_tc <= PADDED_STRING("#TC-4", 32);
WAIT FOR 10 ns;
test_case <= '0';
WAIT;
END PROCESS;
END RTL;
