[SOLVED] VHDL code "skip" a line in write procedure
Raeiu
Newbie level 5
Hi everyone, first of all sorry for my bad english.
I have a problem with this code. It generates a csv file where writes stimuli for a TB (external).
It writes a first line of text with signals name, in the second line should write the first test case (text), after this writes signals and then: second test case, signals, third test case ecc.
An example of what i would like to achieve:
#simENADResetEnableCLK
#TC-1
00101
10100
#TC-2
#TC-3
But it "skip" the second line of text: it writes a line of signals and after #TC-1 and i don't understand why. (see attach file)
For write test cases texts i used a process that, when the signal test_case is '1', signal tc_write write the line, test_case turn '0', wait for xx ns, and then the signals (surely there is a better way to do this).
I hope I was clear in my explanation.
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_TEXTIO.ALL;
USE STD.TEXTIO.ALL;
USE STD.ENV.STOP;
ENTITY write_stimuli IS
END write_stimuli;
ARCHITECTURE RTL OF write_stimuli IS
    SIGNAL simCLK     : STD_LOGIC;        --simulation clk
    SIGNAL simENA    : STD_LOGIC;        --simulation enable. It's used on tb (external)
    SIGNAL write_tc    : STRING(1 TO 32);
    SIGNAL test_case: STD_LOGIC;
-- FUNCTION STRING PAD
    FUNCTION PADDED_STRING(s: STRING; n: POSITIVE) RETURN STRING IS
        VARIABLE ps: STRING(1 TO n) := (OTHERS => ' ');
            BEGIN
            IF s'LENGTH >= n THEN
                ps := s(1 TO n); --- truncate string
            ELSE
                ps(1 TO s'LENGTH) := s;
                ps(s'LENGTH + 1 TO n) := (OTHERS => ' ');
            END IF;
        RETURN ps;
    END;
-- PROCEDURE
    PROCEDURE PWRITE(VARIABLE l: INOUT LINE; msg: IN STRING) IS
        VARIABLE tab : CHARACTER := ';';
        BEGIN
            WRITE(l, msg);
            WRITE(l, tab);
    END PROCEDURE;
    PROCEDURE PWRITE(VARIABLE l: INOUT LINE; sig: IN STD_LOGIC) IS
        BEGIN
            WRITE(l, sig);
            WRITE(l, tab);
    END PROCEDURE;
    PROCEDURE TCWRITE(VARIABLE l: INOUT LINE; sig: IN STRING; FILE f: TEXT) IS
        BEGIN
            WRITE(l, sig);
            WRITE(l, tab);
            WRITELINE(f, l);
    END PROCEDURE;
-- DICHIARAZIONE DEI SEGNALI
-- In questa sezione bisogna scrivere i segnali preceduti dal prefisso
-- "my". Questi sono i segnali necessari per la simulazione.
    SIGNAL reset : STD_LOGIC;
    SIGNAL enable : STD_LOGIC;
    SIGNAL clk    : STD_LOGIC;
    SIGNAL D        : STD_LOGIC;
    SIGNAL Q        : STD_LOGIC;
    BEGIN
    write_process: PROCESS
        FILE stimulus     : TEXT OPEN WRITE_MODE IS ("Stimoli.csv");
        VARIABLE lo     : LINE;
        VARIABLE text_done : BOOLEAN := FALSE;
        VARIABLE cont    : natural := 1;
            BEGIN
                IF (text_done = FALSE) THEN                    -- Write first line on csv
                    PWRITE(lo, "#simENA");
                    PWRITE(lo, "D");
                    PWRITE(lo, "reset");
                    PWRITE(lo, "enable");
                    PWRITE(lo, "clk");
                    PWRITE(lo, "EXPECTED");
                    PWRITE(lo, "Q");
                    PWRITE(lo, "RESULT");
                    WRITELINE(stimulus, lo);
                    text_done := TRUE;
                END IF;
                IF (text_done = TRUE) THEN                     -- write test case
                    IF (test_case = '1') THEN
                        TCWRITE(lo, write_tc, stimulus);
                    END IF;
                END IF;
                IF (text_done = TRUE) THEN                    -- Write signals on csv
                    WAIT UNTIL simCLK <= '1';
                    PWRITE(lo, simENA);
                    PWRITE(lo, D);
                    PWRITE(lo, reset);
                    PWRITE(lo, enable);
                    PWRITE(lo, clk);
                    PWRITE(lo, string'(" "));
                    PWRITE(lo, Q);
                    cont := cont + 1;
                        IF (cont = 30) THEN
                            FILE_CLOSE(stimulus);
                            STOP;
                        END IF;
                END IF;
    END PROCESS;
-- SIGNAL PROCESS
        simENA_process: PROCESS
        BEGIN
            simENA <= '0';
            WAIT FOR 10 ns;
            simENA <= '1';
            WAIT FOR 70 ns;
            simENA <= '0';
            WAIT FOR 10 ns;
            simENA <= '1';
            WAIT;
    END PROCESS;
    D_process: PROCESS
        BEGIN
            D <= '0';
            WAIT FOR 40 ns;
            D <= '1';
            WAIT FOR 80 ns;
            D <= '0';
            WAIT FOR 20 ns;
            D <= '1';
            WAIT;
    END PROCESS;
    reset_PROCESS: PROCESS
        BEGIN
            reset <= '1';
            WAIT FOR 10 ns;
            reset <= '0';
            WAIT FOR 30 ns;
            reset <= '1';
            WAIT FOR 10 ns;
            reset <= '0';
            WAIT FOR 30 ns;
            reset <= '1';
            WAIT;
    END PROCESS;
    enable_process: PROCESS
        BEGIN
            enable <= '0';
            WAIT FOR 80 ns;
            enable <= '1';
            WAIT FOR 80 ns;
            enable <= '0';
            WAIT FOR 30 ns;
            enable <= '1';
            WAIT;
    END PROCESS;
    myclk_process: PROCESS
        BEGIN
            clk <= '0';
            WAIT FOR 10 ns;
            clk <= '1';
            WAIT FOR 10 ns;
    END PROCESS;
    Q_process: PROCESS
        BEGIN
            Q <= '0';
            WAIT FOR 20 ns;
            Q <= '1';
            WAIT FOR 20 ns;
            Q <= '0';
            WAIT FOR 20 ns;
            Q <= '1';
            WAIT FOR 20 ns;
            Q <= '0';
            WAIT;
    END PROCESS;
-- SIMULATION CLK
    simCLK_process: PROCESS
        BEGIN
        simCLK <= '0';
        WAIT FOR 10 ns;
        simCLK <= '1';
        WAIT FOR 10 ns;
    END PROCESS;
-- WRITE TEST CASE
write_TC_process: PROCESS
        BEGIN
            test_case <= '1';
            write_tc <= PADDED_STRING("#TC-1", 32);
            WAIT FOR 10 ns;
            test_case <= '0';
            WAIT FOR 60 ns;
            test_case <= '1';
            write_tc <= PADDED_STRING("#TC-2", 32);
            WAIT FOR 10 ns;
            test_case <= '0';
            WAIT FOR 20 ns;
            test_case <= '1';
            write_tc <= PADDED_STRING("#TC-3", 32);
            WAIT FOR 10 ns;
            test_case <= '0';
            WAIT FOR 40 ns;
            test_case <= '1';
            write_tc <= PADDED_STRING("#TC-4", 32);
            WAIT FOR 10 ns;
            test_case <= '0';
            WAIT;
    END PROCESS;
END RTL;
  • stimoli.zip
I´m not a specialist in VHDL ..
but on a quick view it seems you expect the code to be processed line after line like in a processor.
But this isn´t the case with VHDL. The code is processed in parallel.
Thus I guess writing line#2 and line #3 follow the same condition, thus the latest true "condition" wins.
--> A solution can be to use a variable to count for lines.
Basically coding a state machine that switches state after the currently running function has finished
Example: (pseudo code)
* i = 1
* if I = 1 then do function A
* if I = 1 then do function B
Results in "doing function B" only. Function A never becomes processed.
The line " if I = 1 then do function A" is basically useless.
VHDL is hardware description. Thus learn to think "as parallel processing hardware" -- for get about "serial processing software".
Klaus
Sorry but i'm a little rusty with VHDL. I write a fsm with this logic:
  1. if simRESET = '1', stay state 0 (st0) else next_state
  2. if simRESET = '0' pass on st1
  3. In st1 if test_done = false write first line text. If test_done = true pass on st2
  4. in st2 if test_case = '1' write line of text TC else pass on st3
  5. in st3 if test_case = '0' write signals else return on st2. If cont = 30 close file and stop
Simulation does nothing i must kill the run. Here the code:
fsm_process: PROCESS(simRESET)
        BEGIN
            if (simRESET = '1') THEN
                state <= st0;
            else
                state <= next_state;
            end if;
    END PROCESS;
        VARIABLE lo     : LINE;
            BEGIN
                case state IS
                    when st0 =>
                        if(simRESET = '1')THEN
                            next_state <= st0;
                        ELSE
                            next_state <= st1;
                        end if;
                    when st1 =>
                        if(text_done = FALSE)then
                            PWRITE(lo, "D");
                            PWRITE(lo, "clk");
                            PWRITE(lo, "Q");
                            text_done := true;
                        end if;
                        if (text_done = true) then
                            next_state <= st2;
                        end if;
                    when st2 =>
                        if (test_case = '1') then
                        else
                            next_state <= st3;
                        end if;
                    when st3 =>
                        if (test_case = '0') THEN
                            PWRITE(lo, simENA);
                            PWRITE(lo, D);
                            PWRITE(lo, reset);
                            PWRITE(lo, enable);
                            PWRITE(lo, clk);
                            PWRITE(lo, Q);
                            cont := cont + 1;
                            IF (cont = 30) THEN
                                next_state <= st4;
                            END IF;
                        ELSE
                            next_state <= st2;
                        END if;
                    when st4 =>
                        STOP;
                end case;
    END PROCESS;
Can someone help me please?
I'm taking about this:
                    END IF;
                END IF;
(Sadly one can not give text a color in a CODE window)
Ther is twice: " IF (text_done = TRUE) THEN "
Both tasks are in the same process.
Both tasks will start at the same time, will try to work in parallel .... and may collide.
As said, I´m not a specialist. Maybe others can help you with coding.
Klaus
I understood what you meant. I'm waiting for someone who knows more about vhdl
Do you mind to post complete code of your test? Present code is missing some signal declarations.
Sure. I had truble whit my internet line.
(To compact i have attached the files).
i did some modification. Now the code doesn't crash but it still doesn't write.
P.S: text_write write first line on csv with signals names and tc_write write tests cases.
EDIT: i saw that the fsm has been written bad. Now the code write on csv: first line of text, first test case and signals (bad). I think there is a problem on a case c. It don't switch at status b when tc_write = '1'
  • write_stimuli.zip
Semi-solved. First the code:
FSM
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_textio.all;
use std.textio.all;
use std.env.stop;
entity fsm_stimuli is
    port(
    --    FSM SIGNALS
        signal FSMclk             : in std_logic;
        signal FSMtc_write         : in std_logic;
        signal FSMtext_write     : in std_logic;
        signal FSMwrite_tc         : in string(1 to 32);
    --    COMPONENT SIGNALS
        signal COMPsimena         : in std_logic;
        signal COMPpreset         : in std_logic;
        signal COMPreset         : in std_logic;
        signal COMPenable         : in std_logic;
        signal COMPclk            : in std_logic;
        signal COMPd             : in std_logic;
        signal COMPq             : in std_logic
end fsm_stimuli;
architecture rtl of fsm_stimuli is
-- PROCEDURE
    procedure pwrite(variable l: inout line; msg: in string) is
        variable tab : character := ';';
        begin
            write(l, msg);
            write(l, tab);
    end procedure;
    procedure pwrite(variable l: inout line; sig: in std_logic) is
        begin
            write(l, sig);
            write(l, tab);
    end procedure;
    procedure ptcwrite(variable l: inout line; sig: in string; file f: text) is
        begin
            write(l, sig);
            write(l, tab);
            writeline(f, l);
    end procedure;
--    STATE DECLARETION
    type states is (write_sig_name, write_csv);
    signal state : states;
-- WRITING PROCESS
    begin
        process (FSMclk, FSMtc_write, FSMtext_write)
        file stimulus     : text open write_mode is ("stimoli.csv");
        variable lo     : line;
        variable cont     : natural := 0;
            begin
                if (FSMtext_write = '1') then
                    state <= write_sig_name;
                else
                    case state is
                        when write_sig_name =>                            -- write first line on csv with signals names
                            if (FSMclk = '1') then
                                pwrite(lo, "#simENA");
                                pwrite(lo, "D");
                                pwrite(lo, "reset");
                                pwrite(lo, "preset");
                                pwrite(lo, "enable");
                                pwrite(lo, "clk");
                                pwrite(lo, "--EXPECTED--");
                                pwrite(lo, "Q");
                                pwrite(lo, "--RESULT--");
                                writeline(stimulus, lo);
                            end if;
                            if (FSMtext_write = '0') then
                                state <= write_csv;
                            end if;
                        when write_csv =>
                            if (FSMtc_write = '1') then                    -- write tests cases and signals on csv
                                ptcwrite(lo, FSMwrite_tc, stimulus);
                            elsif (FSMtc_write = '0') then
                                pwrite(lo, COMPsimena);
                                pwrite(lo, COMPd);
                                pwrite(lo, COMPreset);
                                pwrite(lo, COMPpreset);
                                pwrite(lo, COMPenable);
                                pwrite(lo, COMPclk);
                                pwrite(lo, string'(" "));
                                pwrite(lo, COMPq);
                                cont := cont + 1;
                                if (cont = 30) then                         -- counter for stop simulation and close file
                                    file_close(stimulus);
                                    stop;
                                end if;
                            end if;
                    end case;
                end if;
        end process;
end rtl;
TB:
library ieee;
use std.textio.all;
entity write_stimuli_tb is
end write_stimuli_tb;
architecture rtl of write_stimuli_tb is
-- COMPONENT DECLARATION
    component fsm_stimuli is
        port(
    --    FSM SIGNALS
    end component;
-- SIGNALS DECLARATION
    -- SIGNALS FOR FSM
    signal FSMclk              : std_logic;
    signal FSMtc_write         : std_logic;
    signal FSMtext_write     : std_logic;
    signal FSMwrite_tc         : string(1 to 32);
    -- SIGNALS FOR COMPONENT
    signal COMPsimena     : std_logic;
    signal COMPpreset     : std_logic;
    signal COMPreset     : std_logic;
    signal COMPenable     : std_logic;
    signal COMPclk        : std_logic;
    signal COMPd         : std_logic;
    signal COMPq         : std_logic;
-- STRING PAD FUNCTION
    function padded_string(s: string; n: positive) return string is
        variable ps: string(1 to n) := (others => ' ');
            begin
            if s'length >= n then
                ps := s(1 to n); --- tronca la stringa
            else
                ps(1 to s'length) := s;
                ps(s'length + 1 to n) := (others => ' ');
            end if;
        return ps;
    end;
    begin
-- UUT DECLARATION
        uut: fsm_stimuli port map(
            FSMclk => FSMclk,
            FSMtc_write => FSMtc_write,
            FSMtext_write => FSMtext_write,
            FSMwrite_tc => FSMwrite_tc,
            COMPsimena => COMPsimena,
            COMPpreset => COMPpreset,
            COMPreset => COMPreset,
            COMPenable => COMPenable,
            COMPclk => COMPclk,
            COMPd => COMPd,
            COMPq => COMPq
-- SIGNALS PROCESS
        simena_process: process
        begin
            COMPsimena <= 'Z';
            wait for 20 ns;
            COMPsimena <= '0';
            wait for 10 ns;
            COMPsimena <= '1';
            wait for 70 ns;
            COMPsimena <= '0';
            wait for 10 ns;
            COMPsimena <= '1';
            wait;
    end process;
    d_process: process
        begin
            COMPd <= 'Z';
            wait for 20 ns;
            COMPd <= '0';
            wait for 40 ns;
            COMPd <= '1';
            wait for 80 ns;
            COMPd <= '0';
            wait for 20 ns;
            COMPd <= '1';
            wait for 20 ns;
            COMPd <= '0';
            wait;
    end process;
    myreset_process: process
        begin
            COMPreset <= 'Z';
            wait for 20 ns;
            COMPreset <= '1';
            wait for 10 ns;
            COMPreset <= '0';
            wait for 30 ns;
            COMPreset <= '1';
            wait for 10 ns;
            COMPreset <= '0';
            wait for 30 ns;
            COMPreset <= '1';
            wait for 20 ns;
            COMPreset <= '0';
            wait for 100 ns;
            COMPreset <= '1';
            wait for 10 ns;
            COMPreset <= '0';
            wait for 10 ns;
            COMPreset <= '1';
            wait;
    end process;
    mypreset_process: process
        begin
            COMPpreset <= 'Z';
            wait for 20 ns;
            COMPpreset <= '0';
            wait for 20 ns;
            COMPpreset <= '1';
            wait for 10 ns;
            COMPpreset <= '0';
            wait for 30 ns;
            COMPpreset <= '1';
            wait for 10 ns;
            COMPpreset <= '0';
            wait for 140 ns;
            COMPpreset <='1';
            wait;
    end process;
    myenable_process: process
        begin
            COMPenable <= 'Z';
            wait for 20 ns;
            COMPenable <= '0';
            wait for 80 ns;
            COMPenable <= '1';
            wait for 80 ns;
            COMPenable <= '0';
            wait for 30 ns;
            COMPenable <= '1';
            wait;
    end process;
    myclk_process: process
        begin
            COMPclk <= '0';
            wait for 10 ns;
            COMPclk <= '1';
            wait for 10 ns;
    end process;
    myq_process: process
        begin
            COMPq <= 'Z';
            wait for 20 ns;
            COMPq <= '0';
            wait for 20 ns;
            COMPq <= '1';
            wait for 20 ns;
            COMPq <= '0';
            wait for 20 ns;
            COMPq <= '1';
            wait for 20 ns;
            COMPq <= '0';
            wait for 30 ns;
            COMPq <= '1';
            wait for 20 ns;
            COMPq <= '0';
            wait for 20 ns;
            COMPq <= '1';
            wait for 50 ns;
            COMPq <= '0';
            wait for 10 ns;
            COMPq <= '1';
            wait for 10 ns;
            COMPq <= '0';
            wait;
    end process;
-- FSM CLOCK
    simclk_process: process
        begin
        FSMclk <= '1';
        wait for 10 ns;
        FSMclk <= '0';
        wait for 10 ns;
    end process;
-- FSM TEXT WRITE
    simtext_write_process: process
        begin
            FSMtext_write <= '1';
            wait for 5 ns;
            FSMtext_write <= '0';
            wait;
    end process;
-- FSM TESTS CASES WRITE
write_tc_process: process
        begin
            FSMtc_write <= '0';
            wait for 10 ns;
            FSMtc_write <= '1';
            FSMwrite_tc <= padded_string("#tc-1", 32);
            wait for 10 ns;
            FSMtc_write <= '0';
            wait for 60 ns;
            FSMtc_write <= '1';
            FSMwrite_tc <= padded_string("#tc-2", 32);
            wait for 10 ns;
            FSMtc_write <= '0';
            wait for 20 ns;
            FSMtc_write <= '1';
            FSMwrite_tc <= padded_string("#tc-3", 32);
            wait for 10 ns;
            FSMtc_write <= '0';
            wait for 40 ns;
            FSMtc_write <= '1';
            FSMwrite_tc <= padded_string("#tc-4", 32);
            wait for 10 ns;
            FSMtc_write <= '0';
            wait;
    end process;
end rtl;
The problem is here:
                                pwrite(lo, COMPd);
When FSMtc_write = '1' it write test case and it work but doesn't write signal at the same step (see attached file). The signals highlighted in red are not written.
I thought to add anoter state after write_csv i tried something like this:
when write_csv =>
    else
        write_sig <= '1';            -- signal declared to write signals on csv
        state <= write_signals
    end if;
when write_signals =>
    --pwrite all signals
    cont := cont + 1;
          stop;
end if;
    if (tc_write = '1') then
        write_sig <= '0';
        state <= write_csv;
    end if;
write_sig is declared in architecture of fsm. it's a flag for write signals on csv. But this code doesn't work: the simulation doesn't stop and csv is written badly.
Any suggestion?
EDIT: Solved in this way: added pwrite(signal) in statement FSMtc_write = '1' in write_csv state.
Code looks good! To tackle the skipped line issue, double-check the timing of test_case transitions. Simplifying the test case handling might enhance clarity. Happy coding
