[SOLVED] How to add spice model (LIb) files to awr
hellotoke
Newbie level 5
How to add spice model (LIb file) files to awr for trasnsitor BFP196WH6327XTSA1
for LNA design .
please help i tried adding a nonlinear gummel poon model then change the parameter's individually manually but the gain is 5db higher than the s parameter's model in awr .
Please help how to add this spice file(LIB) which i got from mouser,or if you have any advice on what i did wrong
Attched is the spice (lib) files
  • Infineon-RFTransistor-SPICE.lib-SM-v02_10-EN (7).zip
You don't have to import this SPICE file into AWR.
Infineon released a Design Kit for AWR, download it and install it.
see i have it but how do you use this design kit ,how do you add the transistor model
  • RFTransistor-AWR-MWO-Design-Kit - Copy.zip
