How to add library to cadence AWR?
mohamis288
Full Member level 3
Hello,
How can I add the the following library to cadence AWR? Actually I have added .gds file to this software, however, It is supposedly just a layout file. I can not find any element for schematic simulation.
  • RF_POWER_AWR_DESIGNKIT_AWRE_V13.zip
Solution
This is Generic DK for all RF Power products of NXP. You should also download "particular" DK for the component which you intend to use and combine those in a subdirectory. Each particular DK has *.ini file and you can start-up with.
Project-->Process Library-->Add/Remove Library
OR
File-->New with Library-->Browse then...
OR
Hello,
Thank you for your answer. But it tries to find out a .ini format file ,while this format does not exist in this document. Only these formats are available in the folder:
.mod , .mdl , .gds , .syf , .dll
That's it.
Solution
