writing random numbers in PIC16F1936 Internal EEPROM
Hi,my codes are as follows
PHP:
	LIST		P = P16F1936
	__CONFIG H'8007',H'3FAA'
	__CONFIG H'8008',H'3FBC'
	INCLUDE		<P16F1936.INC>
	INCLUDE		<PARAMETERS.INC>
	UDATA_SHR
W_TEMP		RES	1	;LOCATION FOR SAVING 'WREG' DURING INTERRUPT
STATUS_TEMP	RES	1	;LOCATION FOR SAVING 'STATUS' DURING INTERRUPT
FLAGS		RES	1	;FLAGS REGISTERS USED TO INDICATE DIFFERENT STATUS
FREQ_REF_H	RES	1	;REFERANCE FREQUENCY INPUT(MSB) IN TIME COUNTS
FREQ_REF_L	RES	1	;REFERANCE FREQUENCY INPUT(LSB) IN TIME COUNTS
SET_FREQ	RES	1	;REFERANCE FREQUENCY INPUT IN COUNTS
TEMP_LOC	RES	1	;GENERAL PURPOSE TEMPORARY LOCATION
TEMP_LOC_1	RES	1	;GENERAL PURPOSE TEMPORARY LOCATION
TEMP_LOC_2	RES	1	;GENERAL PURPOSE TEMPORARY LOCATION
NO_1_LSB	RES	1	;NUMERATOR(LSB) AND QUOTIENT(LSB) OR MULTIPLIER(LSB)
NO_1_MSB	RES	1	;NUMERATOR(MSB) AND QUOTIENT(MSB) OR MULTIPLIER(MSB)
NO_2_LSB	RES	1	;DENOMINATOR(LSB) OR MULTIPLICAND(LSB)
NO_2_MSB	RES	1	;DENOMINATOR(MSB) OR MULTIPLICAND(MSB)
RESULT_LSB	RES	1	;RESULT OF MULTIPLICATION(LSB)/REMAINDER(LSB)
RESULT_MSB	RES	1	;RESULT OF MULTIPLICATION(MSB)/REMAINDER(MSB)
VDC_COUNT	RES	1	;DIGITAL COUNT OF DC BUS VOLTAGE
	UDATA
TABLE_OFFSET1	RES	1	;PHASE1 OFFSET TO THE SINE TABLE(0)
TABLE_OFFSET2	RES	1	;PHASE2 OFFSET TO THE SINE TABLE(120)
TABLE_OFFSET3	RES	1	;PHASE3 OFFSET TO THE SINE TABLE(240)
TMR2_INT_COUNT	RES	1	;COUNTER TO MEASURE 4MS USING TMR2 OV INT
SINE_TABLE_RAM	RES	0X14	;SINE TABLE
	EXTERN	SET_ADC_GO
	EXTERN	NEW_FREQ
	EXTERN	FLAG_FREQ
	EXTERN	DEC_COUNTER_LSB
	EXTERN	DEC_COUNTER_MSB
	EXTERN	ACC_COUNTER_LSB
	EXTERN	ACC_COUNTER_MSB
	EXTERN	TEMP_COUNTER_LSB
	EXTERN	TEMP_COUNTER_MSB
	EXTERN	TEMP_FREQ
	GLOBAL	SET_FREQ
	GLOBAL	FLAGS
	GLOBAL	NO_1_LSB
	GLOBAL	NO_1_MSB
	GLOBAL	NO_2_LSB
	GLOBAL	NO_2_MSB
	GLOBAL	SET_FREQ
	GLOBAL	FREQ_REF_L
	GLOBAL	FREQ_REF_H
	GLOBAL	TEMP_LOC
	GLOBAL	TEMP_LOC_1
	GLOBAL	TEMP_LOC_2
	GLOBAL	RESULT_MSB
	GLOBAL	RESULT_LSB
;MACRO FOR MULTIPLICATION - 8X8 UNSIGNED
MULT    MACRO   BIT			;MACRO FOR UNSIGNEDMULTIPLICATION
	BTFSC   NO_1_LSB,BIT
	ADDWF   RESULT_MSB,F
	RRF     RESULT_MSB,F
	RRF     RESULT_LSB,F
	ENDM				;END OF MACRO FOR MULTIPLICATION
;POWER ON RESET VECTOR LOCATION
STARTUP	CODE	0X00			;RESET VECTOR ADDRESS
	GOTO	START
	CODE	0X04			;INTERRUPT VECTOR LOCATION
	GOTO	ISR_INT			;GOTO INTERRUPT SERVICE ROUTINE
PROG0	CODE
START
;INITIALIZATION OF THE PORTS AND TIMERS
	BANKSEL	WDTCON
	CLRF	WDTCON
	CLRF	FLAGS			;CLEAR ALL FLAGS
	BANKSEL	FLAG_FREQ
	CLRF	FLAG_FREQ		;CLEAR ALL FLAGS
	BANKSEL TRISB
	BSF TRISB,3
	BSF TRISB,5
	BSF TRISC,2
	MOVLW 0XD7
	MOVWF TRISB
	BANKSEL TRISA
	MOVLW 0X0F
	MOVWF TRISA ;Set RA0,RA1,RA2,RA3,RA4 as input pins on PORTA
	BANKSEL TRISC
	MOVLW 0x03
	MOVWF TRISC  ;Set PORTC as output PORT
	BANKSEL PORTC
	BCF PORTC,4
	BCF PORTC,5
	BCF PORTC,7
	;BSF TRISC,2
;	BSF TRISB,3
;	BSF TRISB,5
	BANKSEL	PR2
	MOVLW	PR2_VALUE		;LOAD PR2 VALUE TO PR2 REGISTER
	MOVWF	PR2
	MOVLW	0X0C
	BANKSEL CCP1CON
	MOVWF	CCP1CON			;CCP1,CCP2 AND CCP3 CONFIGURED TO PWM
	BANKSEL CCP2CON
	MOVWF	CCP2CON
	BANKSEL CCP3CON
	MOVWF	CCP3CON
	BANKSEL CCPTMRS0 ;select the TMR2 on which CCP1,CCP2 and CCP3 are based
    MOVLW 0x00
	MOVWF CCPTMRS0
	BCF T2CON,0
	BCF T2CON,1
	BANKSEL APFCON
	MOVLW 0XFF
	MOVWF APFCON
	MOVLW 0X10
	BANKSEL PWM1CON
	MOVWF PWM1CON
	BANKSEL PWM1CON
	MOVWF PWM2CON
	BANKSEL PWM3CON
	MOVWF PWM3CON
	BANKSEL CCP1AS
	MOVLW 0X0F
	MOVWF CCP1AS
	BANKSEL CCP2AS
	MOVWF CCP2AS
	BANKSEL CCP3AS
	MOVWF CCP3AS
	BANKSEL PSTR1CON
	MOVLW 0X1F
	MOVWF PSTR1CON
	BANKSEL PSTR2CON
	MOVWF PSTR2CON
	BANKSEL PSTR3CON
	MOVWF PSTR3CON
	CALL	STOP_MOTOR		;STOP MOTOR
	BANKSEL T2CON
	BSF	T2CON,TMR2ON		;TIMER2 ON
	CALL	COPY_TABLE_TO_RAM	;COPY SINE TABLE FROM PROGRAM MEMORY TO RAM FOR FASTER ACCESS
	;CALL	STOP_MOTOR		;STOP MOTOR
;INITIALIZE ADC REGISTERS
	BANKSEL	ADCON0
	MOVLW 0b00000111
	;MOVLW	0X91
	MOVWF	ADCON0			;CONFIGURE FOR 32TOSC AND CHANNEL FOR CONVERSION - RA2 (DC BS VOLTAGE)
	BANKSEL ADCON1
	MOVLW 0B00100111
	;MOVLW	0x0B			;CONFIGURE RA0-RA3 AS ANALOG INPUT
	MOVWF ADCON1
	BANKSEL ANSELA
	MOVLW d'0'
	MOVWF ANSELA
	;MOVWF	ADCON2
	;MOVLW	0X31			;SETTING OF ACQUISITION TIME FOR ADC (~25usec)
	;MOVWF	ADCON0          ;TO BE CHECKED for equivalence/////////////////////////////////////////////////////////////////////////////
	MOVLW	0XFF			;RA0-RA3 INPUT and RA4-RA7 OUTPUT
	MOVWF	TRISA
;TIMRE1 INITIALIZATION WITH PRESCALER - USED FOR SETTING OF MOTOR FREQ.
	MOVLW	0X31			;LOAD THE T1CON WITH CONTROL WORD
	MOVWF	T1CON			;FOR TMR1 ON AND PRESCALAR IS 1:8, INTERNAL CLOCK
;TIMRE0 INITIALIZATION WITH PRESCALER - USED FOR ACCELERATION,DECELERATION
;AND ADC TRIGGER FOR FREQ. CONV.
	BANKSEL INTCON
	CLRF	INTCON			;DISABLE ALL INTERRUPTS AND FLAGS ASSOCIATED WITH
	CLRF	PIR1			;DISABLE ALL INTERRUPT FLAGS
	CLRF	PIR2			;DISABLE ALL INTERRUPT FLAGS
	BANKSEL PIE1
	BANKSEL PIE2
	CLRF	PIE1			;DISABLE ALL INTERRUPTS
	CLRF	PIE2			;DISABLE ALL INTERRUPTS
	MOVLW	0X03			;SET #POR AND #BOR FLAGS
	MOVWF	PCON
	BSF	INTCON,INTE		;ENABLE RB PORT CHANGE INTERRUPT FOR RB4
	BSF	INTCON,PEIE		;PERIPHERAL INTERRUPTS ENABLE
	BSF	INTCON,GIE		;GLOBAL INTERRUPT ENABLE
;INFINITE LOOP
LOOP
	BTFSS	FLAGS,TIMER1_OV_FLAG	;IS TMR1 OV FLAG SET?
	GOTO	BYPASS			;NO
	BCF	FLAGS,TIMER1_OV_FLAG	;CLEAR TMR1 OV FLAG
	CALL	UPDATE_PWM_DUTYCYCLES	;YES, UPDATE THE PWM DUTY CYCLE WITH NEW VALUE
 	CALL	UPDATE_TABLE_OFFSET	;UPDATE 3 OFFSETS
BYPASS
	CALL	SET_ADC_GO		;START AD CONVERSION AND CALCULATE TMR1 RELOAD VALUES BASED ON POT SETTING
	CALL	KEY_CHECK		;CHECK KEYS CHANGE
	GOTO	LOOP			;GO BACK TO MAIN LOOP
;INTERRUPT SERVICE ROUTINE
ISR_INT
	MOVWF 	W_TEMP 			;COPY W TO A TEMPORARY REGISTER
	SWAPF 	STATUS,W 		;SWAP STATUS NIBBLES AND PLACE INTO W REGISTER
	MOVWF 	STATUS_TEMP 		;SAVE STATUS TO A TEMPORARY REGISTER IN BANK0
	BANKSEL	PIR1
	BTFSC	INTCON,INTF		;RB INTERRUPT?   External interupt test
	GOTO	CHECK_FAULT		;YES - OVER CURRENT FAULT
	nop
	BTFSC	PIR1,TMR1IF		;TIMER1 OVERFLOW INTERRUPT?
	GOTO	TIMER1_OVERFLOW		;YES - INTERRUPT FOR UPDATING TMR1 REGISTERS BASED ON POT SETTING
	BTFSC	PIR1,ADIF		;ADC CONVERSION COMPLETE INTERRUPT?
	GOTO	AD_CONV_COMPLETE	;YES - CONVERSON RESULT 'F - MOTOR FREQUENCY' OR 'V - DC BUS VOLTAGE'
	BTFSC	PIR1,TMR2IF
	GOTO	TMR2_ISR
POPUP					;RETRIEVE SAVED WREG AND STAUS REGISTER VALUES
	SWAPF	STATUS_TEMP,W 		;SWAP ORIGINAL STATUS REGISTER VALUE INTO W (RESTORES ORIGINAL BANK)
	MOVWF 	STATUS 			;RESTORE STATUS REGISTER FROM W REGISTER
	SWAPF 	W_TEMP,F 		;SWAP W_TEMP NIBBLES AND RETURN VALUE TO W_TEMP
	SWAPF 	W_TEMP,W 		;SWAP W_TEMP TO W TO RESTORE ORIGINAL W VALUE WITHOUT AFFECTING STATUS
	RETFIE				;RETURN FROM INTERRUPT
TIMER1_OVERFLOW				;TMR1 OVERFLOW ISR
	MOVF	FREQ_REF_H,W
	MOVWF	TMR1H			;LOAD THE HIGHER BYTE OF SPEEDCOMMAND TO TMR1H
	MOVF	FREQ_REF_L,W
	MOVWF	TMR1L			;LOAD THE LOWER BYTE OF SPEEDCOMMAND TO TMR1L
	BSF	FLAGS,TIMER1_OV_FLAG
	BCF	PIR1,TMR1IF		;CLEAR TMR1IF
	GOTO	POPUP
CHECK_FAULT
	MOVF	PORTB,F			;READ PORTB TO ITSELF TO END MISMATCH CONDITION
	BTFSS	FLAGS,MOTOR_RUNNING
	GOTO	NO_ACTION
	BTFSS	PORTB,FAULT_BIT		;CHECK FOR FAULT BIT
	GOTO	THERE_IS_FAULT		;YES, FAULT OCCURRED, STOP MOTOR
	CALL	RUN_MOTOR_AGAIN		;FAULT CLEARED?
NO_ACTION
	BCF	INTCON,INTF	;RUN MOTOR AGAIN
	GOTO	POPUP
THERE_IS_FAULT				;YES,FAULT IS THERE
	BCF	INTCON,INTF
	GOTO	POPUP
AD_CONV_COMPLETE			;ADC INTERRUPT
	BCF	PIR1,ADIF		;ADIF FLAG IS CLEARED FOR NEXT INTERRUPT
	BTFSS	FLAGS,V_F_FLAG		;DOES CONVERSION RESULT REFLECT DC BUS VOLTAGE?
	GOTO	CONV_IS_FREQ		;NO - READ RESULT AS POT SETTING OF FREQ.
	GOTO	CONV_IS_BUS_VOLTAGE	;YES - READ RESULT AS DC BUS VOLTAGE
CONV_IS_FREQ
	BANKSEL	NEW_FREQ
	MOVF	ADRESH,W		;READ AD CONVERSION RESULT
	MOVWF	NEW_FREQ 		;CHECK FOR LOWER AND UPPER ALLOWED LIMIT OF FREQ.
	SUBLW	0X13			;MINIMUM FREQUENCY SET TO 5HZ (SCALING FACTOR X4)
	BTFSS	STATUS,C		;IS POT SETTING FOR FREQ, MORE THAT LOWER SET LIMIT?
	GOTO	CHECK_UPPER_LIMIT_FREQUENCY	;YES - NOW CHECK UPPER LIMIT
	MOVLW	0X14			;NO - SET FREQ. TO LOWER ALLOWED LIMIT - 5HZ (X4)
	MOVWF	NEW_FREQ
	GOTO	POPUP
	MOVLW	0XF1
	SUBWF	NEW_FREQ,W
	BTFSS	STATUS,C		;IS POT SETTING MORE THAN ALLOWED UPPER LIMIT OF FREQ?
	GOTO	POPUP			;NO - RETURN FROM INTERRUPT
	MOVLW	0XF0			;YES - SET FREQ TO UPPER ALLOWED LIMIT - 60HZ (X4)
	MOVWF	NEW_FREQ
	GOTO	POPUP
CONV_IS_BUS_VOLTAGE
	MOVF	ADRESH,W
	MOVWF	VDC_COUNT
	SUBLW	LIMIT_V_LOW		;UV LIMIT SET TO 20% OF 115VAC = 92VAC
	BTFSS	STATUS,C		;IS DC BUS VOLTAGE LESS THAN LOWER LIMIT?
	GOTO	CHECK_UPPER_LIMIT_VOLTAGE	;NO - NOW CHECK UPPER LIMIT
	BANKSEL TRISC
	BSF	TRISC,4	;YES - TURN ON LED TO INDICATE SAME
	BCF	FLAGS,MOTOR_RUNNING	;CLEAR MOTOR_RUNNING FLAG
	GOTO	POPUP			;RETURN FROM INTERRUPT
	MOVLW	LIMIT_V_HIGH		;OV LIMIT SET TO 20% OF 115VAC = 138VAC
	SUBWF	VDC_COUNT,W
	BTFSS	STATUS,C		;IS DC BUS VOLTAGE MORE THAN UPPER LIMIT?
	GOTO	VOLTAGE_WITHIN_LIMIT	;NO
	BANKSEL TRISC
	BSF	TRISC,5	;YES - TURN ON LED TO INDICATE SAME
	BANKSEL TRISC
	BSF	TRISC,4		;DC BUS VOLTAGE WITHIN SPECIFIED LIMIT
	BCF	TRISC,5
TMR2_ISR
	BCF	PIR1,TMR2IF
	BANKSEL	TMR2_INT_COUNT
	DECFSZ	TMR2_INT_COUNT,F
	GOTO	POPUP
	MOVLW	0X50
	MOVWF	TMR2_INT_COUNT
	BANKSEL	FLAG_FREQ
	BSF	FLAG_FREQ,DELAY_4MS	;SET 4MS DELAY FLAG
#IFNDEF	RAMP
	GOTO	POPUP
#ELSE
	BTFSS	FLAG_FREQ,CHANGE_FREQ	;IS CHANGE IN FREQ REQUIRED?
	GOTO	POPUP			;NO - RETURN TO MAIN ROUTINE
	BTFSC	FLAG_FREQ,DEC_ACC_F	;IS DECELEARTION REQUIRED?
	GOTO	ACC_FREQ		;NO - ACCELERATION IS REQUIRED
DEC_FREQ
	BANKSEL	TEMP_COUNTER_LSB
	DECFSZ	TEMP_COUNTER_LSB,F	;IS DEC_COUNTER_LSB ZERO AFTER DECREMENT?
	GOTO	POPUP			;NO - COME OUT OF INTERRUPT
	BANKSEL	TEMP_COUNTER_MSB
	MOVF	TEMP_COUNTER_MSB,F
	BTFSS	STATUS,Z		;IS DEC_COUNTER_MSB ZERO?
	GOTO	DECREASE_TEMP_DEC_COUNTER_MSB	;NO
	DECF	SET_FREQ,F		;DECREASE SET_FREQ COUNT BY 1
	BANKSEL	DEC_COUNTER_LSB		;RELOAD DEC_COUNTER TO TEMP_COUNTER
	MOVF	DEC_COUNTER_LSB,W
	MOVWF	TEMP_COUNTER_LSB
	BANKSEL	DEC_COUNTER_MSB
	MOVF	DEC_COUNTER_MSB,W
	MOVWF	TEMP_COUNTER_MSB
	GOTO	POPUP
	DECF	TEMP_COUNTER_MSB,F	;DECREASE DEC_COUNTER_MSB BY 1
	GOTO	POPUP
ACC_FREQ
	DECFSZ	TEMP_COUNTER_LSB,F	;IS ACC_COUNTER_LSB ZERO AFTER DECREMENT?
	BTFSS	STATUS,Z		;IS ACC_COUNTER_MSB ZERO?
	GOTO	DECREASE_TEMP_ACC_COUNTER_MSB	;NO
	INCF	SET_FREQ,F		;INCREASE SET_FREQ COUNT BY 1
	BANKSEL	ACC_COUNTER_LSB		;RELOAD ACC_COUNTER TO TEMP_COUNTER
	MOVF	ACC_COUNTER_LSB,W
	BANKSEL	ACC_COUNTER_MSB
	MOVF	ACC_COUNTER_MSB,W
	GOTO	POPUP
	DECF	TEMP_COUNTER_MSB,F	;DECREASE ACC_COUNTER_MSB BY 1
	GOTO	POPUP
#ENDIF
;THIS ROUTINE WILL UPDATE THE PWM DUTY CYCLE ON CCPX ACCORDING TO THE
;OFFSET TO THE TABLE WITH 0-120-240 DEGREES.
;THIS ROUTINE SCALES THE PWM VALUE FROM THE TABLE BASED ON THE FREQUENCY TO KEEP V/F
;CONSTANT AND LOADS THEM IN APPROPRIATE CCPX REGISTER DEPENDING ON SETTING OF FWD/REV FLAG
	MOVLW	LOW(SINE_TABLE_RAM)
	MOVWF	FSR1L			;BASE ADDRESS OF SINE TABLE IN RAM IS LOADED TO FSR    /added by me
	MOVLW    HIGH(SINE_TABLE) ;Added by me
	MOVWF FSR1H
	BANKSEL	TABLE_OFFSET1
	MOVF	TABLE_OFFSET1,W		;TABLE_OFFSET1 IS COPIED TO WREG
	MOVIW 0[FSR1]
	ADDWF	FSR1,F			;ADRESS TO BE READ=SINE TABLE BASE ADRESS + TABLE_OFFSET1
	BANKSEL	SINE_TABLE_RAM
	MOVF	INDF1,W			;COPY SINE TABLE VALUE, POINTED BY FSR, TO WREG
	BTFSC	STATUS,Z		;CHECK IS VALUE READ ZERO?
	GOTO	PWM1_IS_0		;YES, GOTO PWM1_IS_0
	MOVWF	NO_1_LSB		;NO, SINE TABEL VALUE X SET_FREQ TO SCALE TABLE VALUE BASED ON FREQUENCY SETTING
	CALL	MUL_8X8			;CALL ROUTINE FOR UNSIGNED 8x8 BIT MULTIPLICATION
	MOVF	RESULT_MSB,W		;8 MSB OF 16 BIT RESULT IS STORED
	MOVWF	TEMP_LOC		;AT TEMP_LOC - THIS REPRESENT PWM DUTY CYCLE VALUE FOR PHASE 1
	GOTO	UPDATE_PWM2		;GO FOR UPDATING PWM DUTY CYCLE FOR 2ND PHASE
PWM1_IS_0
	CLRF	TEMP_LOC		;CLEAR PWM DUTY CYCLE VALUE FOR PHASE 1
UPDATE_PWM2
	MOVWF FSR1H
	BANKSEL	TABLE_OFFSET2
	MOVF	TABLE_OFFSET2,W		;TABLE_OFFSET1 IS COPIED TO WREG
	MOVIW 0[FSR1]
	GOTO	PWM2_IS_0		;YES, GOTO PWM2_IS_0
	MOVWF	TEMP_LOC_1		;AT TEMP_LOC_1 - THIS REPRESENT PWM DUTY CYCLE VALUE FOR PHASE 2
	GOTO	UPDATE_PWM3		;GO FOR UPDATING PWM DUTY CYCLE FOR 3RD PHASE
PWM2_IS_0
	CLRF	TEMP_LOC_1		;CLEAR PWM DUTY CYCLE VALUE FOR PHASE 2
UPDATE_PWM3
	MOVWF FSR1H
	BANKSEL	TABLE_OFFSET3
	MOVF	TABLE_OFFSET3,W		;TABLE_OFFSET1 IS COPIED TO WREG
	MOVIW 0[FSR1]
	GOTO	PWM3_IS_0		;YES, GOTO PWM3_IS_0
	MOVWF	TEMP_LOC_2		;AT TEMP_LOC_2 - THIS REPRESENT PWM DUTY CYCLE VALUE FOR PHASE 3
	GOTO	SET_PWM12		;GO FOR CHECKING DIRECTION OF MOTOR ROTATION REEQUIRED
PWM3_IS_0
	CLRF	TEMP_LOC_2		;CLEAR PWM DUTY CYCLE VALUE FOR PHASE 3
SET_PWM12
	BANKSEL	CCPR1L
	BTFSS	FLAGS,MOTOR_DIRECTION	;IS MOTOR_DIRECTION FLAG SET FOR FORWARD ROTATION?
	GOTO	ROTATE_REVERSE		;NO - GO FOR REVERSE ROTATION
	MOVF	TEMP_LOC,W
	MOVWF	CCPR1L			;COPY TEMP_LOC AND TEMP_LOC_1 VALUES TO
	MOVF	TEMP_LOC_1,W		;CCPR1L AND CCPR2L RESPECTIVELY FOR
	MOVWF	CCPR2L			;FOR FORWARD ROTATION OF MOTOR
	BANKSEL TEMP_LOC_2
	MOVF	TEMP_LOC_2,W
	MOVWF	CCPR3L			;COPY TEMP_LOC_2 TO CCPR3L
	BANKSEL TRISC
	BSF	TRISC,3	;TURN ON FWD_REV_LED TO INDICATE FORWARD ROTATION OF MOTOR
	RETURN
ROTATE_REVERSE
	MOVF	TEMP_LOC_1,W		;COPY TEMP_LOC_1 AND TEMP_LOC VALUES TO
	BANKSEL CCPR1L
	MOVWF	CCPR1L			;CCPR1L AND CCPR2L RESPECTIVELY FOR
	MOVF	TEMP_LOC,W		;FOR REVERSE ROTATION OF MOTOR
	BANKSEL CCPR2L
	MOVWF	CCPR2L
	BANKSEL TEMP_LOC_2
	MOVF	TEMP_LOC_2,W
	BANKSEL CCPR3L
	BANKSEL  TRISC
	BCF	TRISC,3	;TURN OFF FWD_REV_LED TO INDICATE REVERSE ROTATION OF MOTOR
	RETURN
;THIS ROUTINE UPDATES THE OFFSET POINTERS TO THE TABLE AFTER EVERY ACCESS
UPDATE_TABLE_OFFSET
	BTFSS	FLAGS,OFFSET1_FLAG	;IF SET INCR. ON TABLE
	GOTO	DECREMENT_OFFSET1
	MOVLW	(SINE_TABLE_ENTRIES-1)	;CHECK FOR THE LAST VALUE ON THE TABLE
	SUBWF	TABLE_OFFSET1,W
	BTFSC	STATUS,C
	GOTO	CLEAR_OFFSET1_FLAG
	INCF	TABLE_OFFSET1,F		;INCREMENT OFFSET1
	GOTO	UPDATE_OFFSET2
CLEAR_OFFSET1_FLAG
	BCF	FLAGS,OFFSET1_FLAG
DECREMENT_OFFSET1
	DECFSZ	TABLE_OFFSET1,F		;DECREMENT OFFSET1
	GOTO	UPDATE_OFFSET2
	BSF	FLAGS,OFFSET1_FLAG
UPDATE_OFFSET2
	BTFSS	FLAGS,OFFSET2_FLAG	;IF SET INCR. ON TABLE
	GOTO	DECREMENT_OFFSET2
	SUBWF	TABLE_OFFSET2,W
	BTFSC	STATUS,C
	GOTO	CLEAR_OFFSET2_FLAG
	INCF	TABLE_OFFSET2,F		;INCREMENT OFFSET2
	GOTO	UPDATE_OFFSET3
CLEAR_OFFSET2_FLAG
	BCF	FLAGS,OFFSET2_FLAG
DECREMENT_OFFSET2
	DECFSZ	TABLE_OFFSET2,F		;DECREMENT OFFSET2
	GOTO	UPDATE_OFFSET3
	BSF	FLAGS,OFFSET2_FLAG
UPDATE_OFFSET3
	BTFSS	FLAGS,OFFSET3_FLAG	;IF SET INCR. ON TABLE
	GOTO	DECREMENT_OFFSET3
	SUBWF	TABLE_OFFSET3,W
	BTFSC	STATUS,C
	GOTO	CLEAR_OFFSET3_FLAG
	INCF	TABLE_OFFSET3,F		;INCREMENT OFFSET3
	RETURN
CLEAR_OFFSET3_FLAG
	BCF	FLAGS,OFFSET3_FLAG
DECREMENT_OFFSET3
	DECFSZ	TABLE_OFFSET3,F		;DECREMENT OFFSET3
	RETURN
	BSF	FLAGS,OFFSET3_FLAG
	RETURN
;THIS ROUTINE CHECKS FOR THE KEYS STATUS. 2 KEYS ARE CHECKED, RUN/STOP AND
;FORWARD(FWD)/REVERSE(REV)
KEY_CHECK
	BANKSEL	PORTB
	;BTFSS	PORTB,RUN_STOP_KEY	;IS RUN_STOP_KEY PRESSED?
	BTFSS PORTB,3
	GOTO	RUN_STOP_KEY_PRESSED	;YES
	BTFSC	FLAGS,MOTOR_RUNNING	;IS MOTOR RUNNING?
	GOTO	FWD_REV_CHECK		;YES
	RETURN
	BTFSS	FLAGS,MOTOR_RUNNING	;IS MOTOR ALREADY RUNNING?
	GOTO	RUN_MOTOR		;MO
	BANKSEL	TRISC
	;BCF	LED_PORT,RUN_STOP_LED
	BCF	TRISC,7
	BCF	FLAGS,MOTOR_RUNNING	;CLEAR FLAG TO INDICATE THE SAME
WAIT_1
	;BTFSS	PORTB,RUN_STOP_KEY	;INFINITE LOOP TILL THE TIME PRESSED SWITCH IS RELEASE3
	BTFSS PORTB,3
	GOTO	WAIT_1
	RETURN
RUN_MOTOR
	BANKSEL	TRISC
	BSF	TRISC,7
	BSF	FLAGS,MOTOR_RUNNING
WAIT_2
	;BTFSS	PORTB,RUN_STOP_KEY	;INFINITE LOOP TILL THE TIME PRESSED SWITCH IS RELEASED
	BTFSS PORTB,3
	GOTO	WAIT_2
FWD_REV_CHECK
	BANKSEL	PORTB
	;BTFSC	PORTB,FWD_REV_KEY	;FWD/REV KEY PRESSED?
	BTFSC PORTB,1
	RETURN				;NO
	CALL	STOP_MOTOR
	MOVLW	0X64			;ADJUST THIS PARAMETER TO SET TIME BETWEEN CHANGE OF DIRECTION OF ROTOATION OF MOTOR
	MOVWF	TEMP_LOC_2
WAIT_FOR_MOTOR_TO_STOP
	CALL	DELAY
	DECFSZ	TEMP_LOC_2,F
	GOTO	WAIT_FOR_MOTOR_TO_STOP
	BANKSEL	PORTB
	MOVF	FLAGS,W
	ANDLW	0X01
	BTFSS	STATUS,Z
	GOTO	SET_REV_DIRECTION
SET_FWD_DIRECTION
	BSF	FLAGS,MOTOR_DIRECTION
WAIT_3
	;BTFSS	PORTB,FWD_REV_KEY	;INFINITE LOOP TILL THE TIME PRESSED SWITCH IS RELEASED
	BTFSS PORTB,1
	GOTO	WAIT_3
	RETURN
SET_REV_DIRECTION
	BCF	FLAGS,MOTOR_DIRECTION
WAIT_4
	BTFSS PORTB,1
	GOTO	WAIT_4
	RETURN
;THIS ROUTINE STOPS THE MOTOR BY DRIVING THE PWMS TO 0% DUTY CYCLE. ALSO DISABLE
;SELECT INTERRUPT TO MAINTAIN STOP CONDITION OF MOTOR
STOP_MOTOR
	BANKSEL	PIE1
	BCF	PIE1,TMR1IE
	BCF	PIE1,TMR2IE
	BCF	PIE1,ADIE
	CLRF	CCPR3L
	BANKSEL PORTA
	BCF	PORTA,DRIVER_ENABLE
	CLRF	CCPR1L
	CLRF	CCPR2L
	CLRF	TABLE_OFFSET1
	CLRF	TABLE_OFFSET2
	CLRF	TABLE_OFFSET3
	MOVLW	0X14
	MOVWF	SET_FREQ		;RESET MOTO FREQUENCY TO 5Hz
	BANKSEL	NEW_FREQ
	MOVWF	NEW_FREQ
	BANKSEL	TEMP_FREQ
	MOVWF	TEMP_FREQ
	RETURN
;THIS ROUTINE STARTS MOTOR FROM PREVIOUS STOP WITH MOTOR PARAMETERS INITIALIZED
RUN_MOTOR_AGAIN
	CALL	INIT_MOTOR_PARAMETERS
	BANKSEL	PIE1
	BSF	PIE1,TMR1IE
	BSF	PIE1,ADIE
	BSF	PIE1,TMR2IE
	MOVLW	0X50
	RETURN
;THIS ROUTINE INITIALIZES THE PARAMETERS REQUIRED FOR MOTOR INITIALIZATION.
	MOVLW	0X09			;INITIALIZE THE TABLE OFFSETS TO 3 REGISTERS
	MOVWF	TABLE_OFFSET1		;SUCH THAT THEY HAVE 120 DEG. PHASE SHIFT WITH EACH OTHER
	MOVLW	0X03
	MOVWF	TABLE_OFFSET2
	MOVLW	0X0F
	MOVWF	TABLE_OFFSET3
	BSF	FLAGS,OFFSET1_FLAG	;OFFSET FLAGS INITIALIZATION
	BANKSEL	TMR1H
	MOVLW	0XF9			;TIMER1 INITIALISATION
	MOVWF	FREQ_REF_H
	MOVWF	TMR1H
	MOVLW	0X37
	MOVWF	TMR1L
	MOVWF	FREQ_REF_L
	MOVLW	0XB1
	MOVWF	TMR0
	BSF	PORTA,DRIVER_ENABLE
	RETURN
;ROUTINE FOR 8*8 BIT MULTIPLICAION
MUL_8X8
	CLRF    RESULT_MSB
	CLRF    RESULT_LSB
	MOVF    SET_FREQ,W	        ;MOVE THE MULTIPLICAND TO W REG.
	BCF     STATUS,C    		;CLEAR THE CARRY BIT IN THE STATUS REG.
	MULT    0
	MULT    1
	MULT    2
	MULT    3
	MULT    4
	MULT    5
	MULT    6
	MULT    7
	RETLW   0
;UPON INITIALIZATION THE SINE TABLE CONTENTS ARE COPIED TO THE RAM FROM
;PROGRAM MEMORY
COPY_TABLE_TO_RAM
	MOVWF	FSR1
	MOVLW	0X13
	MOVWF	TEMP_LOC
	CLRF	TEMP_LOC_1
COPY_AGAIN
	MOVWF	PCLATH
	MOVF	TEMP_LOC_1,W
	CALL	SINE_TABLE
	MOVWF	INDF1
	INCF	TEMP_LOC_1,F
	INCF	FSR1,F
	DECFSZ	TEMP_LOC,F
	GOTO	COPY_AGAIN
	MOVLW	LOW(SINE_TABLE_RAM)	;FSR POINTS TO THE STARTING OF THE TABLE
	MOVWF	FSR1
	RETURN
;GENERAL PURPOSE DELAY ROUTINE - PRESENT DELAY TIME ~38msec
DELAY
	MOVLW	DELAY_COUNT1
	MOVWF	TEMP_LOC
DEC_TEMP_LOC
	MOVLW	DELAY_COUNT2
	MOVWF	TEMP_LOC_1
DEC_TEMP_LOC_1
	DECFSZ	TEMP_LOC_1,F
	GOTO	DEC_TEMP_LOC_1
	DECFSZ	TEMP_LOC,F
	GOTO	DEC_TEMP_LOC
	RETURN
;EQUATION USED FOR CALCULATION OF SINE TABLE ENTRIES = (SIN(ANGLE)+1)*FF/2
;ANGLES ARE FROM 270 DEG. TO 90 DEG. STEP SIZE = 10 DEG.
TABLE	CODE	0X0005
SINE_TABLE
	ADDWF	PCL,F
	RETLW	0X00
	RETLW	0X01
	RETLW	0X07
	RETLW	0X11
	RETLW	0X1D
	RETLW	0X2D
	RETLW	0X3F
	RETLW	0X53
	RETLW	0X69
	RETLW	0X7F
	RETLW	0X95
	RETLW	0XAB
	RETLW	0XBF
	RETLW	0XD1
	RETLW	0XE1
	RETLW	0XED
	RETLW	0XF7
	RETLW	0XFD
	RETLW	0XFF
;END OF FILE
	END
;unfortunately I am not able to adjust the speed of asynchronous Motor and also find below the PWM signals I am getting(from CCP1,CCP2 and CCP3) I think they can`t be used for three phase system,
please help!!
did you ever mention motor speed adjust before? It may be , but I can´t remeber now.
your scope:
these may be valid PWM signals of a three phase sine.
But with the shown little time it is impossible to say.
Show us a scope picture of a fullwave (at 50Hz this means 20ms).
If the graphic resolution is too low we need at least 90 degree = 5ms.
Klaus
Hello KlausSt,It is not possible to visualise the the graph at 50HZ,the signla will resemble to a line because the frequency is very high!!
Thx
...Then use a 10k ohm and 330nF LPF at each output and show us the three signals.
Klaus
At 20ms the waveform is not clear,find it in attachment it is giving the high frequency of PWM for controlling IGBTs bridge!!
At 20mS sweep time you should see one cycle of sine wave from each output and the sine waves shifted by 120 degrees from each other. It looks like only a short part of two cycles is showing and the third looks unfiltered. The partial waveforms (if they are sine shaped) suggests your are reading through the table of values far too quickly and trying to produce a much higher output frequency than 50HZ.
Brian.
See the signal I am getting with the R and C in serie but with the period changed a little bit,It gives the triangular wave and also not adjustable I have to be able to adjust with a potentiometer but I simulate in proteus and it does n`t allow the adjustment.
The figure shows that the system is not really reading the sine wave values I provided in the look up table,could you please help me to address those values and make the system able to adjust the frequency,I am really at the maximum of what I can handle with these codes.!!
Please help!!
your scope does not show 20ms as requested. It shows about 100us. So it´s useless.
Added:
Pleas show all three signal with input selector = "DC".
All three signals should be in the range 0..Vcc
You could play with a 20ms ...100ms per scope view.
Klaus
