FreshmanNewbie
Advanced Member level 1
Below is a circuit which I found that is used for Protective Earth Neutral detection.
The PEN_ON comes from MCU and PEN_dET does to an MCU.
P20, is a current transformer.
Can someone explain me the working of this circuit and why it is required?
This is an application of an EV charger module that takes mains input and then meters, & then AC chargers the EV battery. Between the AC main and EV charger connector, where would this CT come? There's a Relay (which is controlled by an MCU) in the line between AC main and the connector.
