Windmiller
Member level 4
wp100!
Here's my current code for the PIC16F628A..
It seems to work fine when I was testing it on the 16F.
Regards
/ Morgan
LIST p=16f628A
errorlevel -302 ; ???
__CONFIG _INTRC_OSC_NOCLKOUT & _MCLRE_ON & _LVP_OFF & _WDT_OFF & _PWRTE_ON & _BODEN_ON
ORG 0x00
GOTO INIT
ORG 0x04 ; Interrupt vector
BCF INTCON, INTF ; Yes, clear interrupt flag
BCF INTCON, GIE ;
CALL IntRupt ; Interrupt routine
RETFIE
INIT:
Counter EQU 0x20 ; Delay counter
SaveW EQU 0x40 ; To save W register
DHexVal EQU 0x28 ; Hex value to display
Tens EQU 0x41 ; Dec value to display LCD
Ones EQU 0x42 ; Dec value to display LCD
count1 EQU 0x34 ; used in delay routine
counta EQU 0x35 ; used in delay routine
countb EQU 0x36 ; used in delay routine
Disp10 EQU 0x30 ; Displ 1:0
Disp11 EQU 0x31 ; Displ 1:1
BANKSEL TRISA
MOVLW b'00000000' ; Set 0 to input
MOVWF TRISA
BANKSEL 0x5 ;
CLRF 0x5 ; Set All B pins to 0
BANKSEL TRISB
MOVLW b'00000001' ; Set 0 to input
MOVWF TRISB
BANKSEL 0x6 ;
CLRF 0x6 ; Set All B pins to 0
movlw 0x07 ; Turn comparators off and enable
movwf 0x1f ; pins for I/O functions
MOVLW b'00110000' ; xx------ unimplemented
; --11---- prescaler 1:8
; ----0--- Timer1 osc = off
; -----x-- ignored when Timer1 osc = off
; ------0- Clock source = internal (Fosc/4)
; -------0 Stop timer1
MOVWF 0x10 ; Set timer
BSF OPTION_REG, INTEDG ; interrupt on positive
BCF INTCON, INTF ; clear interrupt flag
BSF INTCON, INTE ; mask for external interrupts
BSF INTCON, GIE ; enable interrupts
; 1 Sec delay routine using Timer1
; With current Timer1 setting (Prescaler 1:8, Reload 3036)
; a timer overflow happen each 500mSec, so we just
; repeat it twice
MOVLW .8 ;
MOVWF Counter ; Counter = 4
CALL InitTmr1 ; Init timer1
START: ; Main loop
CALL CheckTmr1 ; Check if tmr1 is done
movwf 0x22 ; Move returnvalue to register
btfsc 0x22,0 ; Is it 0, jump next line.
CALL CheckCounter ; Is it 1, Check counter.
CALL DispLCD ; Display values on LCDs
goto START
CheckTmr1
BTFSS PIR1, TMR1IF ; Timer1 Overflow?
RETLW 0x0 ; Still going, return 0
RETLW 0x1 ; Time's up!
CheckCounter:
DECFSZ Counter, F ; Decrease CounterA * 500ms
GOTO Jump1 ; If not zero Jump1
GOTO Jump2 ; If zero Jump2
Jump1: CALL InitTmr1 ; Restart timer
RETURN ; Return
Jump2: MOVLW .8 ; Reset Counter = 4
MOVWF Counter ; Counter = 2
CALL TimesUp ; Do the thingy
RETURN ; Return
DispLCD
; Display part 0/1 on displ 1
MOVF Ones, W ; Put Ones into W
CALL LCD10 ; Translate W into display10
MOVWF Disp10 ; Save
MOVF Tens, W
CALL LCD20
IORWF Disp10, W ; Add together
BCF PORTA, 0
BSF PORTA, 1 ; Turn on part 0 for disp 1,2
MOVWF PORTB ; Display part 0 on disp 1,2
CALL LCD11 ; Translate W into display11
MOVWF Disp11 ; Save
MOVF Tens, W
CALL LCD21
IORWF Disp11, W ; Add together
BCF PORTA, 1
BSF PORTA, 0 ; Turn on part 1 for disp 1,2
MOVWF PORTB ; Display part 1 on disp 1,2
RETURN ; Done
LCD10
ADDWF 0x2, F
RETLW b'00010110' ; 0:0
RETLW b'00001100' ; 1:0
RETLW b'00011100' ; 2:0
RETLW b'00001100' ; 3:0
RETLW b'00001010' ; 4:0
RETLW b'00001110' ; 5:0
RETLW b'00011110' ; 6:0
RETLW b'00000000' ; 7:0
RETLW b'00011110' ; 8:0
RETLW b'00001010' ; 9:0
LCD11
ADDWF 0x2, F
RETLW b'00001110' ; 0:1
RETLW b'00000000' ; 1:1
RETLW b'00001010' ; 2:1
RETLW b'00001110' ; 3:1
RETLW b'00001100' ; 4:1
RETLW b'00000110' ; 5:1
RETLW b'00000110' ; 6:1
RETLW b'00001110' ; 7:1
RETLW b'00001110' ; 8:1
RETLW b'00001110' ; 9:1
LCD20
ADDWF 0x2, F
RETLW b'11100000' ; 0:0
RETLW b'01100000' ; 1:0
RETLW b'11000000' ; 2:0
RETLW b'11100000' ; 3:0
RETLW b'01100000' ; 4:0
RETLW b'10100000' ; 5:0
RETLW b'10100000' ; 6:0
RETLW b'11100000' ; 7:0
RETLW b'11100000' ; 8:0
RETLW b'11100000' ; 9:0
LCD21
ADDWF 0x2, F
RETLW b'10110000' ; 0:1
RETLW b'01110000' ; 2:1
RETLW b'01100000' ; 3:1
RETLW b'11000000' ; 4:1
RETLW b'11100000' ; 5:1
RETLW b'11110000' ; 6:1
RETLW b'00000000' ; 7:1
RETLW b'11110000' ; 8:1
RETLW b'11000000' ; 9:1
TimesUp
MOVF 0x21, W ; RPM
MOVWF DHexVal ; Display value
CLRF 0x21 ; Clear out, start over
CALL HexToDec ; Convert Hex to Dec
RETURN
HexToDec ; Convert Hex to dec
CLRF Ones
CLRF Tens
movf DHexVal, W ; Get hex value to convert
movwf Ones
repeat: movlw .10
subwf Ones, W
btfss STATUS, C
RETURN ; Done converting
movwf Ones
incf Tens, f
goto repeat
InitTmr1
BCF T1CON, TMR1ON ; Stop Timer1
BCF PIR1, TMR1IF ; Clear Timer1 overflow flag
MOVLW b'11011100' ; Load
MOVWF TMR1L ; Timer1
MOVLW b'00001011' ; with
MOVWF TMR1H ; Reload Value
BSF T1CON, TMR1ON ; Start Timer1
RETURN
IntRupt
MOVWF SaveW ; Save what's in W
INCF 0x21, f ; Increase RPM counter
MOVF SaveW, W ; Restore W
RETURN ; And return
End
Regards
/ Morgan
