jason_class said:Hi All
Anyone knows how much the soi cmos process cost more than a stadard bulk cmos process?
Any link for this info?
Thanks a lot
Jason
jason_class said:Hi Scottieman and Sky High
Thank you so much.
I have tried to look up all info in this forum on soi cmos.
I will check the IBM paper you mentioned.
By the way Scottieman, I saw from books and papers that soi cmos is compatible with bulk cmos integration. What do you mean by the process issue?
Kindly enligthen
Thank you all.
best regards
Jason
Humungus said:The problem concerning the silicon fil uniformiti only arises in fully depleted as Vth of transistors operating under this regime depends on silicon thickness. Also some special care must be take when chosing the implant energies as the distribution cernter of the implanted ions must lay at the center of the active silicon. Actually, thinner than 100nm silicon layers are needed ~50nm.
On the other hand, partially depleted devices are much less sensitive to silicon thickness variations.
That is why, current SOI processes are using PD devices, but FD soi is coming up.
On the other hand, short channel effects are easier to control in SOI than in bulk.
jason_class said:Hear that all the integration method such as Ldd and STI .. applied in bulk cmos can be used to fabricate cmos soi. But any general changes must be made?
best regards
Jason
