Why is the radiation pattern not oriented to the 0 degree?
imtiaz369
Member level 1
Why is the radiation pattern not oriented to the 0 degree? I got this raditaion pattern after simulation, but I wonder to know that why is the radiation pattern not oriented to the 0 degree instead of 90 dgree?
It is the xyz plane of my antenna. Could you please help me to fix it??
And, is my radiation pattern is wrong??
Could you please help me, how I should explain this radiation pattern? where is the θ & Φ?
And, this radiation pattern is oriented toward 90 degrees, how can I change it to 0 degrees?
I've also attached my antenna coordinates here!
where is the θ & Φ?
You can find the orientation of theta and phi in the xyz axis here (and hopefully in HFSS manual):
Your antenna has main beam at theta=90° and phi=0°, that is in the xy plane (PCB plane) and not upwards in z direction. No problem with that, if you show the antenna and related xyz coordinate system.
If you insist to "fix" this and get main beam at theta=0°: You could rotate the complete model so that the antenna radiates to z axis, but there might be easier solutions. My EM solver (Empire XPU) has a feature to rotate antenna patterns in postprocessing, maybe HFSS has a similar feature.
Why you don't rotate the entire physical structure and point the directive pattern to whatever direction you want.
This is what I meant by "rotate the complete model so that the antenna radiates to z axis".
I think the problem here was to understand that Theta=0 in the antenna pattern display is fixed (z-axis), no matter where the antenna radiates.
LaTeX Commands Quick-Menu:
