Which gates act as universal gates?
Re: Universal Gates
Universal gates are
NAND
NOR
MUX
thanks
sarfraz
Re: Universal Gates
i dont know about mux but i read "nand and nor gates are universal gates" because by using these two gates only we can make any type of circuit....
Re: Universal Gates
i think Nand nor and inverter are universal gates
and i also mean that inverter is the main universal gate
with this we can buld any system
Re: Universal Gates
NAND and NOR are the universal gates
MUX is the universal circuit from which you can make any gate logic
Universal Gates
Hi
Kinjal is right.
Mux is conmbinational logic built using gates,which can be used to build any higher logic.
Re: Universal Gates
Hey!
Is implication really a universal gate? How can one make an AND gate using the IMPLICATION gate?
Thanks in advance
Re: Universal Gates
Here is a link to the universal gates: **broken link removed**. All the circuits are interactive, so you can click on the inputs to see how they work.
As far as NAND and NOR go, if you have ever build a logic gate using transistors, then you know the following: All gates are networks of inverters; the simplest gates are NAND and NOR; all other gates are in fact build with inverters, NAND gates, and NOR gates. These designs are the most cost effective. Mathematically, on the other hand, we can probably show other universal gates, but they won't be cost effective.
The link I give you has more information. or just go to **broken link removed** and navigate from there.
Good luck
