Which gates act as universal gates?
tronix
Full Member level 1
Which gate apart frm nand and NOR CAN ACT AS UNIVERSAL GATE ?
Re: Universal Gates
tronix,
Exclusive OR. It can be argued that the exclusive OR can be constructed from NAND and/or NOR gates. However, the same arguemnent can be used for the NAND and NOR: A NAND CAN be constructed from NORs and a NOR can be constructed from NANDs.
Regards,
Kral
    tronix
Re: Universal Gates
kral
Can u plz give some example like and/or gate constructed frm XOR gates
Re: Universal Gates
as far as i know,
only, NAND and NOR gates are universal gates
Universal Gates
actually nand and nor are universla "as far as i know"
ex.
NOT >>>> A nor A =A' >>>>> A nand A= A'
OR >>>> A' nand B' = A or B >>> (A nor B)' = A or B
and >>>> A' nor B' = A and B >>> (A nand B)'=A and B
not any bar can be acheived by "NOT"
Added after 6 minutes:
sorry is "apart" means besides , if so then excuse me >>
a MUX is a universal gate
F=A B + C B' >>>>>> A=0 >>> F=C and B'
>>>>>> A=1 >>> F= C or B
    tronix
Re: Universal Gates
thats seems to be a solution
Thnx
Re: Universal Gates-Mux,Inhibit,implication,HA etc.
Universal gates are those from which we can produce all kind of gates.
following are the examples.
1)And-Or-Not
2)NAND
3)INHIBIT X.Y'
X'Y
4)iMPLICATION X+Y'
X'+Y
5)NOR
6)XOR WITH AND
7)EQUALITY(XNOR) WITH AND
8)MUX
9)HALF ADDER
one can try all these gates to realize each and every gate.
    tronix
Re: Universal Gates
Universal gates are the one, which can be used for implementing any gate like AND, OR and NOT. Also used for implementing gates of any combination of these basic gates. NAND and NOR gates are the only Universal gates.
Re: Universal Gates
NAND , NOR, and MUX may be treated as universal gates.
Universal Gates
Simple schmitt triggered inverters can be used as a universal gate.
They can also be used as pulse generators, pulse stretchers, and clock generators using only a resistor and a capacitor (granted with great variances)
Re: Universal Gates
XOR can also be used as univesal gate:-
XOR with one of its i/p is 1 is called controlled inverter
similarly it canbe used to construct any other gate including AND and OR- only4to5 gates will be required as in the case of NAND and NOR
Re: Universal Gates
well..i guess it is like safwat said:
nand, nor and mux
Re: Universal Gates
I already mentioned all possible universal gates in this post.
XOR is not an universal gate.can u form NAND gate or NOR gate with using only XOR gate...?try...u can't.so XOR is not an universal gate.If u can form NAND gate(which is an universal gate) using XOR gate,then XOR will also become an Universal gate.right....?
Re: Universal Gates
MUX is also an universal gate apart from NAND and NOR gates.
Re: Universal Gates
Hi Sreejith
I tried but couldn't get AND/OR of XORs . Can u plz give ckt
Re: Universal Gates
MUX is also a universal gate, by using MUX,
you can make any digital circuit.
you can try it.
best regards
Universal Gates
mux should be always called as universal circuit not as a logic gate...
Re: Universal Gates
neils_arm_strong said:
XOR,XNOR,NOR,NAND are universal gates.
As already discussed XOR and XNOR can not function as universal gate , A Mux indeed can.
Can u make a and/or/nand/nor frm Xor/Xnor? I think no.
tronix
