umagne
Newbie level 6
Vamsi Mocherla said:Remember that there are two loops in the bandgap circuit.
Loop I
Positive Feedback, which is the bootstrapped diode connected current mirrors which can potentially increase the current.
Loop II
Negative Feedback, which is the loop formed due to the diode in one branch and doide and resistor in another. The current through the resistor will determine the source voltage of the bottom NMOS transistors. Increase or decrease in the current will determine the increase or decrease in the source voltage of the NMOS FETs.
Implication
Now for any stable circuit, the feedback is negative or the negative feedback should dominate the positive feedback. Hence both the feedbacks should act on the same node. Importantly the node at which they sum determine the stability of the circuit for them to be additive. The summing node in this case is the source node with transistors N2 and N4.
Hence the circuit on the left should be stable.
How do you recognize the loops inside a voltage reference? Could you suggest me some references/books where I can find informations on circuit loops about voltage/current reference?
Thanx
