selva500
Junior Member level 3
Hello,
I've sort of figured out why EMPower simulation is not as good as the linear one when the LNA is connected to it. When i connect up the LNA in the schematic and optimize it, the circuit is optimised for the scenario when the LNA is connected. But since the LNA is invisible to EMPower, the EM response isnt very good. Is there a way that I could set up EMPower to take into account the LNA when running the simulation? How do i do this? Currently, I have set the LNA to be replaced by a short circuit in the layout. Do i have to set it up so that the footprint shows up? I wouldnt think that this will make a difference will it? It will be good if I can see the EM response with the LNA attached. I would really appreciate it if someone could tell me how I can do this.
Another question which I have posted before is, Do I need some sort of impedance matching from the LNA to filter and back to the LNA again or I connect it straight to the feed lines (I don’t think the TL from the LNA will be the same width as the feed lines) or can I just omit the feed lines and connect the TL from the LNA straight to the resonators (ie will there be any matching issues)?
