What's wrong with my HFSS model?!
eng.dreamer
Junior Member level 1
Hey all;
I found an antenna design paper, it includes the design and the results.
I tryed to model the design in HFSS but I am not getting the same results!
I've attached the paper and the HFSS file I've made, I want to know what is the problem with my design.
Hi ,
I have opened your file ...but there is no design ...its empty HFSS file.
please re-check.
Regards
Oooooooooops!
I've just uploaded the right one, I will be very thankfull if you helped me
It should be ok now.
please check and let me know.
regards
Mustafa
Thanx mustafa :)
It's behaving better now, but the radiation pattern is not as it should be!
Hounstly I am confused now of what Zo represents! because when you changed the dimensions of the coax & probe, Zo changed . . I used to think it is fixed on 50 ohm whatever the shape of the port was . .
Thanx again
