What's the meaning of "tapped filter"?
STD
Member level 4
Member level 4
Can someone explain it in detail?Thanks.
When working with paralell (edge) transmission line coupled filters, the first and the last resonator usually require a very small coupling gap to input and output lines. This might couse technological problems. In order to avoid this, input and outputs are connected directly to a first resonator at some "tapped" position along the line. This is just to give you a hint what it is all about, you can read more in the book by Hong - Microstrip filters for RF microwave application, it can be downloaded on this site.
flyhigh
this is a way to model the input/output of a filter. In particular it consist in a high impedence connection with the first /last resonator of the filter. The connection point have to be optimize.
midnite
