What's the function of SG3524 IC in an inverter circuit?
jerkymotion
Member level 4
Member level 4
NEPAL
hi every one..
i found this IC...SG3524... on my inverter..which i bought from the market..
i have read the datasheet but could not find the reason behind this IC to be used in inverter.circuit ...my inverter is 50watt...
anyone please can you explain how this IC works..
every help will be appreciated
Re: SMPS control circuit
I'd think the TI dataSheet explains it rather well, incl. appropriate application info.
Reactions: ghewarlal
    V
    ghewarlal
Reactions: jerkymotion
    jerkymotion
    V
Mr Tahmid,i want get 100 khz frekuensi using sg 3524,so we using the formula,but when i make it on pcb and i test and measure with osciloscope,i dont get the frekuensi that i expected
please help me...
The 3524 has unity gain bandwidth 3MHz and the transition times ON+OFF are 0.3usecs .As such you cannot expect to go beyond 33KHZ as you shall need a min gain of 100 for your drives.
The supply is 12VDC max. and the pushpull drives at transformer give saturation drops of approx.1VDC for the swing.As such ferrite winding ratio Pri::sec is 1:10 for getting 220VAC
However , the 3stage Darlington drive pushpull stages can be bettered by using Low Rdon MOSFET like STW80N06 which is 60V/80Amp /Rdson =0.01 ohm.
Well, this is a PWM chip. For understanding PWM:
**broken link removed** ---------> I recommend this
Pulse Width Modulation
Introduction to Pulse Width Modulation (PWM) | Netrino
Okay then, first get your head straight with PWM and how it works and then go through the datasheet:
focus.ti.com/lit/ds/symlink/sg3524.pdf
If then you still don't understand, you'll find many here to help you.
Take this as reference:
Hope this helps.
Tahmid.
can u help me out with d pbc layer of dis schematic
---------- Post added at 17:16 ---------- Previous post was at 17:14 ----------
Hope this helps.
Tahmid.
mr tahmid i have built this circuit of pwm invertor which you have posted i have problem that it is not oscillatin i only get voltage at only one output some time i get on pin14 and pin 11 has no voltage and if i turn off i get voltage at pin 11 and no signal at pin 14 please help what to do
can we obtain variable frequencies using SG3254??
good morning every one,please,mr tahmid i am a child in sg3524,i followed ur blogs on this but not been able to find any,d only one i saw with detailed explanation was sg3525,pls am in need of the functions of all these pins,if u have worked with that before can u help me post the blog address so i can read through,i enjoy that 4 sg3525 (self explanatory)
hey guys need help..i just want to ask, is it possible that using IC sg3524 can have an output of 10 hz frequency and how can i achieve it.
Mr tamid could we design a sine wave inverter circuit using the sg3524 as part of the circuit. Thank u
