What's the difference between Microsim and Orcad pspice?
saryee
Member level 2
Member level 2
difference between microsim and orcad pspice
What's the difference between Microsim and Orcad pspice? Does anyone know that?
The same thing. Orcad bought the microsim and combine with their software. If you plan to use try to use Orcad instead of microsim.
schematic difference
The microsim pspice had their own simplified schematic capture for making the net list. When orcad took over, they had their more complex schematic capture be the generator of the netlist. People complained and the had the option of using either capture loaded on your computer when you installed the program.
If I remember right, microsim used a hardware key.
