What's the difference between MatLab and Labview?
matlab simulink vs. labview
Labview can be used for hardware interface. whereas matlab can be content to calculate.
there are many hardare cards to be adopted labview from NI. to build a complete system.
compare matlab to labview
MusicMan said:
i have a question. can i use labview to simulate FDTD?
i think it can't be used. but i just wanna ask those who know labview well coz i used labview only used labview for a short period of time and i really don't know its capabilities.tnx
i used C++ to simulate FDTD.
mostly i do data analysis,prototype evaluation and simulation with matlab.
i think labview is very easy to handle and i always use it to control instruments such as oscilloscope and data acquisition card, but one of my friend does everything using labview.
compare labview and matlab
With simulations the results from LabView are much more closer to experimental results. Also for similar models in LabView and Simulink, LabView runs faster.
labview matlab comparison
The different is LabVIEW has a beautiful interface and matlab has a programming interface,but believe me the Matlab is beter because LabVIEW is restricted to National Instrument hardwares.
comparison between matlab and labview
Dear friend
Matlab and Labview not same cathegory.
Matlab very powerfull programming script language.
clasical style write code,
use simulink build block or use stateflow. its very flexible and powerfull.
Labview
very powerfull programming tool for NI cards. not writing code u build a picture a lego castle :(.
after time u lost control.
I prefer Matlab.
lab view
adeel.sid said:
In matlab ,NO real time data processing
Matlab 1st store,then process.
But labview can perform real time data processing
hence labview is good from this respect.
But
I refer you to work 1st on matlab as it is more user friendly.
HELP file of matlab can teach u a lot.
Regards,
Not strictly true, check out xPC Target.
what is difference between labview and matlab
Both of these are simulation tools. MATLAB is a technical computing language tool to solve mathematical, signal processing, communications problems while LabView is a design and test tool. MATLAB is better than LabView because it has many many integrated features than anyother simulation package.
fdtd labview
Matlab provides more math power and toolkits than almost any other software. It can fit in any Math, Physics, or Engineering problem.
labview or matlab for data acquisition
both r diff
labview is easier than matlab but mutlab is mucher stronger than labview.
mostly people try to make their projects in matlab.
i also prefer matlab over labview.
compare matlab labview
It is not true. LabView also runs hardware from measurement computing. I was able to install and use USB-1208FS DAQ card.
labview mathscript vs matlab
Matlab or Labview ?
not one of these recent programs are working under W98
I have a old ISA NI488II GPIB card (only drivers for w98) and will use it in association with a Anritsu spectrum analyzer MS2601
is there a solution for ??
greetings
labview
labview for industrial and matlab for scientific applications.
matlab have strong tools for processing.
lavbiew have strong tool for hardware and user interfacing.
labview data acquisition and matlab
We have so many tools,but the thought came to be simple!
I want to be smart, not with the CAD
malab vslabview
Can anybody tell me what is the cost(Price) differece between Matlab and Labview.
For using on mutiple systems(Computer).
For interfacing with Hardware which is better???
labview and matlab
hi friends
i hav a problem...plz help me for control toolbox in labview.....or some examples for control system.... ???
matlab vs labview career competency
guess the difference lies in the data acquisition. in labview, the data acquisition is faster when compared to matlab... tatz y labview is prefered in most of the domains where there is data acquisition from external devices.
