Capacitance.Mv1 and Mv2 transistors have their source and drain tied together. What's the purpose.
From any (of X or Y) to GND .this is VCO circuit, CVar , variable capacitance is measured from which node? X or Y?
No. C(Mv) vs. VDD.and that's the output of the VCO?
Capacitance.
Where's a resistor? Can't see any!
Because they are exactly meant and used as such.why do you think Mv1 Mv2 are functioning like capacitors?
There's no part of the MOS transistors which could serve as resistor: drain and source both are connected to the control voltage. Only their drain+source to gate capacitance is effective.Why you think they aren't like resistors?
An easier way to think of this is to draw the physical structure of a mosfet and then consider the connections. The total capacitance will be Cgs+Cgd including the oxide capacitance.
What about the "r0" from the Early effect ? It not appears because of shortcut between D and S?
You used the model of the NMOS with the capacitors who appears in the high frequency.. but can't see any AC source there...
