deepakchikane
Full Member level 3
- Joined
- Jul 17, 2012
- Messages
- 178
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,298
- Location
- Mumbai, Maharashtra, India, India
- Activity points
- 2,623
Re: 1 coil latching relay driving
Hi FVM,
will single ic can set & reset following relay....
**broken link removed**! for this relay
Hi fvm,
by seeing above images you posted,
There isnt any component wich can drop the voltage..??
are you talking about wich voltage drop..??
I am considering 5v instead of 12 volt supply at collector..
please help will it work for 5v coz i want to reduce the transformer by removing 12 volt regulator stage n want to make it with only 5 v...
i have seen also a h-bridge driver bot costwise it is expensive
Not so well, too much voltage drop. Better use a MOSFET H-bridge. There are integrated low voltage H-bridges available.
Hi FVM,
Hi fvm,
