what to do with this virus ?
k... thanx.... now printscreen the taskmanager and post it.... let us solve try to solve this prob too....
what about ? / X mark i want to remove it as well .
give me steps :--
i can have a try at it only after you post the processes that are running in your system.... printscreen and post your taskmanager....
i edit it check it over your post
inetinfo.exe and btdna.exe are new to me... r u running any programs which might have a process name like that????
end process inetinfo.exe and see what happens...
no !
i try to terminate it but a msg is come like this !
but after end process click
unable to terminate it msg comes
i.e access denied
no ! there is same warning but process ends well
clearly post again which processes you were able to terminate successfully....
does that ?/X disappear after u end process these processes....
this one "btdna.exe."
no still that horror mark is there to check me
what software do have that has processes starting with ash and avg... i think avg is related to antivirus...
close unwanted processes like hotkey.exe etc so that the process responsible for this can be traced....
after click on it a internet explo will open with this
i am trying what you said ok
inetinfo , ashwebsv , ashmaisv, ashserv,ashupdsv, lsass, not responding / access denied .
find the file location of inetinfo.exe and post....
i believe that is the problem creator.... try right clicking and exiting the ?/X... post what it responds to this....
there are two files
here is the locations
file 1
C:\WINNT\system32\inetsrv
file 2
C:\WINNT\ServicePackFiles\i386
r /left click on it will open the what i post early image .
what do u mean by two locations????
actually what are u doing to find the file location....
i did the causal search .
i will get back to you . i hope you will almost kill this horror mark !
thank you again !
i right click the process in task manager and give open file location....
i use windows vista.... i'm not sure whether that option is available in urs..... if it there then try that....
my pc have new virus !
after opening the explore the contains of drive not accessible but showning .txt type icon.
after close it , and reopen it shows the contains , but if we switch to other drive again the .txt icon shows but not accessible.
i'm not able to get u clearly... r u having .txt files which are visible only when u open the drive for the first time???
