antedeluvian
Full Member level 1
From what you have said, I am not sure you have a common reference between the two systems. As I understand it youy only have the 2 wire A & B connecting the systems. If that is the case it is likely that one is floating against the other and sooner or later you are going to violate the +12/-7V spec of teh RS485. Try joining the two grounds together through a ~100R 2W resistor (Vsquared/R=144/100 <2W). If you can't run the wire, at least try to connect the commons of the RS485 drivers to earth/ground (athough this can be tens of volts difference from one location to another).
If you have got the commons connected, you should also consider the possiblilty that the electrical noise is affecting the processor itself and not just the RS485 connection. You will need to come up with some technique to prove that it is only the communications or not.
