What the difference between these 2 mosfets
Gaber Mohamed Boraey
Full Member level 3
Hello
I’ve replaced a mosfet no. JCS3205CH with another one no. IRF3205 , it worked fine , but not for load
Are they equivalent numbers or no?
I noticed only difference the unit in doide in both, do you see any other difference?
the datasheet of each MOSFET isn´t just half a page or a single page. And this is for a reason.
We don´t know what your application requirements are, thus we don´t know which values of the whole datsheets need to be compared.
What is your load ? The application ?
When you say the IRF part does not work with load, what do you observe ? Does it
fail, if so how ?
The two parts are pretty close in terms of thermals, gate charge, breakdown V, current.....
Have you observed gate V transients with a scope, same for drain ? The parts torqued
down with mounting screw to right value ?
Regards, Dana.
Thanks for everyone who cared to answer
The datasheet available on internet, I just couldn’t upload the pdf files here
I’ve tested the gates with hz from multimeter, all are 50hz frequency, but when in load they burn, damaged
The application is ups device, small watt for lid, something for some store cameras I think, don’t remember exactly the load
But I mean with load, that when connect the ups with lamp or something the mosfet damages, while without load it work fine and we have output
The mosfets are 4, take Signals from lm339 comparator and controlled by micro controller atmega 168ap
Maybe the comparator not sending right frequency at load?
They are almost same. IRF3205PBF is a little bit faster.
Faster means it can work with lower frequency?
By the way, here is supplier say it’s compatible mosfets , can be replacement
--- Updated ---
Here
Crummy pictures of what look like used parts, and they say, “ see, they’re the same”.
But forgetting that for the moment, when are you going to post some useful information that people keep asking for? a schematic? a block diagram? And, yes, it will work at slower speed.
I don’t have any information, all the ups come from china with only user Manual and not service manual , so no schematic or block diagram or any information help in repair, that’s why I’m asking here for help
Thanks by the way, I know now that they’re the same , and I think the problem with oscillation, so I will replace the comparator and see
No, its response time seems faster. ( rising and falling time )
Hello
How about the pulse width difference in both?
Attached differente
So, “how about” it? WE don’t know what your requirements are, do you? Does 50ns matter? WE sure dont know.
I think i’m done here.
Hello
Attached differente
Yes there is a 10% difference in total rise and fall delay+time, which is not significant to making it "work" but will affect dissipation slightly.
Hello everyone
I’ve fixed the ups by changing the mosfets with good ones number cs120N04
The problem was that the mosfets bought from local market are bad
Hello everyone
Report problem to distributor then close answer
LaTeX Commands Quick-Menu:
