- Joined
- Jan 22, 2008
- Messages
- 53,300
- Helped
- 14,795
- Reputation
- 29,877
- Reaction score
- 14,324
- Trophy points
- 1,393
- Location
- Bochum, Germany
- Activity points
- 301,872
Transmitter current and duty cycle are the parameters determining the minimal required battery capacity. If you can't go below 135 mA and the 200 ms every 8 s duty cycle, the total 32 Ah/a calculated by CatM in post #6 applies. If your battery voltage is higher than 4V, using a high efficient switching regulator pays. But you can't go below e.g. 9-10Ah/a with a 12V battery. Means you either need to provide a large battery or overthink the intended packet rate and duty cycle.
