T
treez
Thanks, all power to your bow, I missed the 3/4 inch bit too. The datasheet says it is "self priming up to 3m"......so I presume that is how you knew to have it 4 m total.....to give that bit of margin extra. I would never have thought to have the pump sucking water up 2m as well as blowing water up 2m. Do you think the "sucking water up" bit will make the pump needs to use more energy?
From what you say about the unwanted siphon effect, I think we will need a separate water bucket above the 2m high tube, and a separate riser tube will put water in this, and a separate tube will take water down from this?
