radioman
Junior Member level 3
- Joined
- Apr 4, 2002
- Messages
- 29
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Netherlands
- Activity points
- 132
Very small antenna
Hi Dderijken,
About your small antenna, you can go down to 1/10 lambda. That's what they use in social alarming etc.
I've made a very small antenna. It works on 868 MHz (ISM band) and is only 8x13 mm in size. It is a patch antenna on a multi layer PCB. The complete antenna is first simulated with HFSS. The measured reflection coefficient is about -20 dB. The bandwith is about 15 MHz. The impedance is 50 Ohm.
With a transceiver of 1 mW and a basestation with the same transceiver and a rubber duck antenna, you can cover a distance of about 25 meter.
So how small can you go ? Very small !
Hi Dderijken,
