Ahmed Alaa
Full Member level 5
Hi all,
What is the simplest circuit to divide two signals without using a gilbert cell?
thnx,
thnx,
Ahmed Alaa said:Analog voltage/current signals...
Ahmed Alaa said:Yes, an arithmetic divider that operates ideally at any frequency.
Keep on dreaming.an arithmetic divider that operates ideally at any frequency
It's at least the case with gm-multipliers. Some can work as divider by connecting an internal amplifier respectively, others need an additional OP. The manufacturer datasheets tell in detail. A log/antilog circuit computes the quotient directly:all dividers originally multipliers wired as dividers?
q = a/b = exp(log(a) - log(b))
Basically another good suggestion. You have to care however for a linear dependance of either resistance or conductanceWhat about an inverting amplifier with one of the two resistors replaced by a voltage controlled resistor?
