D.A.(Tony)Stewart
Advanced Member level 7
- Joined
- Sep 26, 2007
- Messages
- 9,696
- Helped
- 1,850
- Reputation
- 3,701
- Reaction score
- 2,379
- Trophy points
- 1,413
- Location
- Richmond Hill, ON, Canada
- Activity points
- 62,471
ESR losses in a battery are related to SOC , Battery quality and Ah capacity and CCA rating.
I would fully charge the battery and determine the constant current rise from 12.8V to 11V and use that current as the maximum. Thus when discharged at 11.5 going to 14.4 or so (which is a function of temperature) is a 1.6V rise above fully charged. You can compute I^2*ESR power , but dont't boil the electrolyte. ( listen to it) C/10 C/5 , C, 5C charge ratings etc always depend on battery design, so I expect they assume high Quality batteries.
SAE J537 standards by applying a full charge and a 24-hour rest, followed by a regulated 25A discharge to 10.50V (1.75V/cell).
The above was for Ah capacity testing.. I recall CCA testing used 0'F but no matter it involves reducing 12.5V full charge to 7.5V sustained current for so many seconds (30?) for SAE specs, other standards have different voltages like 8.5 9.5 with higher duration times.
This would obviously overheat the battery if used for charging, but I suspect there is a fractional ratio of CCA for maximum Charging rate.
e.g. 700Ah car batteries routinely have alternators rated at 70 to 100A or 900Ah ones usually on cars with big V-8s with 120A alternators.
I suspect this ratio is 10~15%.
A 5Ah battery is pretty small so a 1C rate of 5A is safe a 4C rate of 20A expects that these are the best quality fresh batteries. otherwise heat rise, gassing, electroplating are all concerns. Heat rise actually improves performance (Lower ESR) but increases aging rate and sulfation rate.
I doubt if the Charge rate is 20A that it has a CCA of 10x this amount, so I would be concerned.
